I got this Recon because it had a bad rod bearing, it knocked while running. I have replaced the crank, rod, and piston to fix that problem. Now the thing doesn't have any spark. I have a peak voltage meter, from work, and it showed that the pulse generator only made .36v AC and the service manual said it should be .7v or higher. I have replaced the pulse generator with a new one and I now only get .256v AC. I have ohm-ed out the new and old pulse generator and the old one has 368 ohms and the new one has 348ohms. Still no spark. I replaced the coil, because it was cheep and I have 0v at the blue/yellow coil connection. I get well over the 100v minimum for the stater and at the ICM. I tested the kill switch and the ignition switch at the ICM as well. The fuses and the diode was tested as well.
I think the issue is still in the pulse generator as I dont get the minimum required voltage but I dont know what else to do. I checked the wire inside the case to the connector and it ohms out at 48ohms. The ground wire in the connector to the casing is 48ohms also. (resistive wire?) I would rather not just throw parts at the problem.
Any ideas?
Any ideas?
