Hello first time here and rather new to atv repair. My 400 ex will catch reverse while in first gear randomly while moving locking up the back end and stalling it. Then it gets stuck in reverse and i cant get it back out (backing all the way out a trail sucks). It wont go in neutral the reverse light goes off neutral light comes on but it just sticks in reverse. If i put it in first i can feel the quad trying to pull forward but reverse is still enagaged. I know 05 06 had there recalls for something like this but nothing about 07.
What do you think the problem is? Lockout shaft? spring? Can i replace the shaft and spring without pulling the motor? Can i just pull the shaft and run no reverse? Any tips are appreciated
Thanks in advance
Welcome to the forums. . .. In 2005/2006 Honda recalled their 400EXs for this problem
2005 & 2006 TRX400EX
Washington, DC (12/14/05) - The following product safety recall was voluntarily conducted by the firm in cooperation with the CPSC. Consumers should stop using the product immediately unless otherwise instructed.
Product: Honda Model Year 2005 and 2006 TRX400EX ATVs Units: About 24,000
Manufacturer: American Honda Motor Corp. Inc., of Torrance, Calif.
Hazard: A safety defect could exist in the transmission that could allow the rider to downshift from 1st gear into reverse without operating the reverse assist (lockout) lever. The reverse lockout spring may not have been properly installed. Unintended engagement of reverse gear while moving forward could lock the rear wheels and cause the rider to lose control.
You should be able to make this repair "in Frame"
In your case the spring may have came off or is broken??
Thank you for your response.
I just bought this machine a few days ago and the Deeper i dig the more i find. The machine goes into second while riding but there is nothing there. Fully let out the clutch and it acts as if its in neutral. Shift forks or is 2nd gear is actually gone? I havent opened anything up yet. Trying to determine if its worth the money and time.
Is there a way to tell if its Shift forks? Or if the gear is gone? Goes into second but it just revs out when i release the clutch.
Thanks again!
