2006 Trx350es
Starts, runs, but display is not there unless I unplug and replug wire socket, gray one up front under plastics with power turned on, once that is done, clock blinks at 1:00 and wont set.
Then I turn off power, turn back on power and display is gone again, until i unplug /replug electric socket to display.
I have 12v to brown/black wire to display. And green wire is ground.
There has to be a constant voltage on one of the wires giving display memory voltage. There in is my problem.
Thank you for any help.
Yes connections are all good, battery is good. Great power to everything, just not to memory for display.
