I looked it up. If my search was correct then you have the diaphram type with two throttles like I described above. Aftermarket $35.......Honda had choices from $105 to Around $140Anyone know what makes the carb slide go up and down on these rancher quads? With my carb in quad using the throttle the slide is not going up and down.
I dont know for which style of carb is on yours. If the top is square then it is a contant Velocity style. A diaphram opens it with engine vacuum. It needs to be running to open. If the throttle is strictly mechanical then it should open with the throttle without the engine running. Another way to know which style you have is to look for a round throttle valve to open. It is in the carb too........located between the throttle slide and the air filter flange. In a way this carb has two throttles the Round valve before the slide........they operate separately.
Yes, the engine must run to create vacuum to pull the slide up. The round valve should rotate at all times.I dont know for which style of carb is on yours. If the top is square then it is a contant Velocity style. A diaphram opens it with engine vacuum. It needs to be running to open. If the throttle is strictly mechanical then it should open with the throttle without the engine running. Another way to know which style you have is to look for a round throttle valve to open. It is in the carb too........located between the throttle slide and the air filter flange. In a way this carb has two throttles the Round valve before the slide........they operate separately.
Thanks! So basically the engine has to be running for slide to move? It's a CV carb. Butterfly in front of round fuel slide
