Welcome to the forums. I would try to mount it as high up and out of the mud as I could get it.
Helmut, thanks for the reply and welcome. I will try to put it under the seat if possible. I have another issue regarding the choke knob. After about 30 seconds the knob goes back in and it will not stay in the out position. I talked with my local dealer and they don't know why. Any ideas? Thanks.
On the choke knob, pull the rubber boot up and you should see a plastic nut. Tighten the nut a little and then pull the choke knob out and see if it stays out. If it doesn't, tighten it a little more and repeat until it stays out.
