Just recently acquired this bike and needing a little guidance. It was not shifting at all. The esp light is flashing (6 blinks). According to the service manual it is the code for the ecu. Well I replaced the angle sensor the shift motor and the ecu. I did the initialization and heard the shift motor sync. It's still blinking (6) and it's giving the -- where the N is supposed to display. I just recently rebuilt the top end but I'm not wanting to dump a whole lot more into a bike that's going to be used to haul deer out of the woods. Any ideas or suggestions would be greatly appreciated.
Welcome to the forum. Check the neutral position switch. It's down by your left heel under the plastic cover when sitting on the bike. I paid only $16 for mine from local dealer and they had in stock.
Had this exact prob with the same year machine. Ended up being the connections under the 'hood'. Just another spot to check, the connections were just dirty & once unplugged & plugged back in it was fine for years. Cheap & free to check, so i would at least try that.
Thanks ATC4ever. The guy I got it from seemed to like to mud ride so that's not out of the realm of possibility. Thanks for the tip and if it will quit lightning here in lower Alabama I'll definitely do some cleaning under there and check and dielectric grease all connections. Thanks for the tip.
