Hi my rancher at 400 4x4 has started blinking "---" when i put it in reverse or when i use the automatic shifting. if i use the esp and shift with the thumb buttons it works fine but still have the problem with reverse. any suggestions as to why or how to fix would be great. thanks
Try resetting the system and see if this helps.
Reset procedures.
The initial resetting procedure is as follows:
While bike is in neutral, turn the key on while holding both the up and down shift buttons at the same time
Then release them and push the up shift button, then the down shift button, and then up again
The N for neutral indicator should change to a double hash line " -- "
Then within 10 seconds open the throttle lever all the way and then back again
You should hear the shift motor reset itself
If N sign does not change to hash marks, repeat procedure as many times as needed
