My bike has a pro circuit silent core muffler and a k&n filter. Been running fine then started bogging down when I would chop the throttle trying to turn around on a tight trail. Carb has 170 main jet and 48 pilot jet installed. First took the carb off and tore apart. Cleaned and installed complete rebuild kit. Re installed, adjusted and still the same. Seems to only do it after it’s warm. Idles a touch ruff but for the most part runs good. If I chop the throttle a little in gear when warm it will bog down and die. Sometimes I can touch the throttle and it goes back to idleing good. I reinstalled the factory air filter and still the same.I purchase a 168 and 172 main with a 50 pilot on the way. Have a new throttle sensor on the way and a ignition coil as well. Any help is very appreciated.
