Hi everyone. New here and looking for help!My bike has a pro circuit silent core muffler and a k&n filter. Been running fine then started bogging down when I would chop the throttle trying to turn around on a tight trail. Stab the gas and let off, the bike will idle down really low then bog down and die.Carb has 170 main jet and 48 pilot jet installed. First took the carb off and tore apart. Cleaned and installed complete rebuild kit. Re installed, adjusted and still the same. Seems to only do it after it’s warm. Idles a touch ruff but for the most part runs good. If I chop the throttle a little in gear when warm it will bog down and die. Sometimes I can touch the throttle and it goes back to idleing good. I reinstalled the factory air filter and still the same.I purchased a 168 and 172 main with a 50 pilot on the way. Have a new throttle sensor,ignition coil and rubber boot for carb on the way. Inspected the boot from the manifold to the front of carb and the rib on the inside opening is half missing/ripped off. Any help is very appreciated.
