I have an 04 rubi that went dead on me in a water hole. I had it wenched out and it fired right up. I rode it the rest of the night and unfortunately it sat for about 1 mo as I did not think I got any water in the motor. Well I got it out to ride it again and it started with the grey smoke so I immediately quit riding it and have changed the oil and oil filter in it twice, pull the spark plug and turned it over a couple of times but no water came from the spark plug hole.
Besides changing the oil twice is there anything else you guys suggest that I do?
The diesel fuel is used because it's cheaper than oil. Definitly do not want to start it with diesel in it. some people use automatic trans fluid because it absorbs water better? Was your oil a milkshake? If so seeing as you already ran it with that in the engine it seems your rings are toast
I should have mentioned I swamped my old Honda big red and after it burned oil and soon after the rod bearings went. Water really takes a dump on your engine only way is to keep flushing it I used diesel wich carries the old watery oil out pretty good
