Hey everybody, I recently got a non running 04 Honda Rubicon. I found that the spark plug wire was off, and the carb needed cleaned. Also the fuel filter was stopped up, which I cleaned the tank and removed. Now it will crank and idle, but only for maybe 10 seconds. If you rev it, it will die faster. It seems to be running out of gas, but I can't figure out why. It has a new line from the tank to the carb. The float is all plastic, there's no way to change the float level. Does anybody have any ideas? Thanks
