1 - 2 of 2 Posts
I've got a trx350te 2 wheel drive with a bad bearing. How or what tool are you using to pull the bearing out of the drum? I'm guessing a pilot bearing puller and a slide hammer....but I'm looking for a recommendation.
front wheel bearing ?, remove the inner dust seal from knuckle, remove large c-clip, flip over right side up, bar/large socket, hammer it down and out, once its down flush, you will need to prop it up on some boards, then hammer on out.
1 - 2 of 2 Posts
