The fan on my 400at rancher stopped working. I replaced it with a new one then took it out for a test ride. After awhile of moderate to hard riding it finally kicked on, but I noticed that the engine had already gotten pretty hot before it did come on. It seemed to me like it took longer for it to come on. I'm I being paranoid or is this normal? Also can anyone tell me where the temp sensor is located?
Thanks,
Welcome to the forums. I'm not real familiar with the 400AT, but I believe the thermo sensor is somewhere on the back of the engine, close to the bottom.
Yep - sounds like the oil temp sensor is either bad or doesn't have a good connection. As Helmut mentioned, check the temp sensor to verify that it is working properly.
There are some other threads here that have some detailed information. Here's one from Helmut on this very subject.
Melsman
I am assuming this is my problem, when i'm plowing my driveway and going through trails for about 10-15 mins the bike wants to stall. But at that time i have notice the temp light and the fan has not came on.
Any suggestions?
So, are you saying that the temp light is on, but the fan is not running? Or are you saying the engine stalls, and the temp light is NOT on and the fan is NOT running?
If the temp light is on, but the fan isn't running - and the fan checks out (as you said previously it does) - then there are only four other items in the circuit - a 15 amp fuse, the electrical connectors, the oil temp sensor, and the ECU.
I'd check the fuse first, then the connectors. If that doesn't do it, then replace the temp sensor. And if that doesn't work, then you could be looking at a faulty ECU.
Melsman
