Good evening everyone? I am new to the thread and am In need of some help here is the situation. Got a little toy that needed some work. The guy I got it from said it just needed a solenoid so couple hundred buck and a compression check and were good to go however now I have a no spark issue.
I replaced cdi box. Ignition coil. Plug. Solenoid carburetor and rectifier. I ohm check the pulse gen and it seems to be all good and the battery is good. I got a neutral light but can only get it to turn over but jumping at silanoid (still no fire). Suggestions? Were to know? Is there a way to bypass the run/kill switch for verification that's an issue?
