1 - 2 of 2 Posts
Must I remove the engine in order to replace the cam chain and tensioner on my 03 Rincon 650?
Thanks for any input :hail:
No, it can be done with the engine in place. You'll have to remove the head cover and the head because the cam is under the head. Then you will have to remove the front engine cover and you will have to remove the torque converter. The timing chain is behind the torque converter.
You can find a repair manual for the 2003 Rincon 650 at this site.
maxmekker.com
1 - 2 of 2 Posts
