Have an 03 Rancher that I keep in garage. Woke one night to gas smells. Checked ATV and found that it was leaking from a small tubing under engine. Took off air filter cover and air filter and found that entire air filter compartment was full of fuel. What?
your float needle in the carb is not shutting off, need to take the carb off and clean it out, hope this helps
Welcome to the forums. X2 on the float needle not shutting off. You better check your oil. If gas was in the airbox, it probably got in your oil, too.
Thanks to you as well, Helmut. I noticed that you are a "Senior Member" of the forum. I will definately check my oil for gasoline.
You sleep in the garage?
