1 - 14 of 14 Posts
Welcome to the forums! We try to keep this forum family friendly. And even though you did star out some of the word we all know what it meant. I edited it accordingly. If there is metal in the oil something is wearing abnormally. And the list of possibilities goes on and on. You will have to start removing parts of the engine to look for the culprit. Start by removing the valve cover and hopefully its just a rocker arm or cam. Sometimes clutch wear can put kind of a grey sludge with a shimmer to it in the oil. You are getting actual metal chunks correct?
If there are no abnormal noises, no grinding, whining, whiring, tapping it may be worth flushing the engine (diesel or kerosene) fitting a new filter and replacing the oil. Try it for a couple hours and then drop the oil and replace the filter again.
The state of your filter is quite alarming but it could well be sloppy workmanship by a previous owner. They may have fixed the problem and not replaced the filter, and it’s not unheard of for people to reuse the oil the drained out!
:grin
He said aluminum...... cam and rockers are steel
As title states just got a 400ex and there are aluminum shavings in the oil, what's the most likely part getting destroyed?
Sent from my SM-G950U using Tapatalk
Your clutch basket and fibers are probably beyond needing replacement .
Don't forget to remove the oil line from the bottom of the tank and the remove the fitting, there is a screen there too. Also behind the clutch side cover is an engine filter screen that is probably just as bad. The oil cooler would require flushing out as well.
Good luck and keep us posted
:grin
I am well aware of what materials things are made of. But if i had a dollar everytime someone said i have aluminum shavings in my oil and i asked did you try a magnet? They said no. And low and behold the magnet dosnt lie. 99.9% of the time metal in these engines oil isnt going to be aluminum.
To the OP. Looks like alot of clutch sludge. Someone never changed the filter by the looks of it. Probably didnt even know it was there and just changed the oil.
:grin
You should build more engines grasshopper... hahaha... that's mostly aluminum. I wanna see the clutch basket. Most of the time steel shavings are gear material and yes rocker and cam.... but the majority is aluminum in that filter.
Sent from my SM-N950U using Tapatalk
He didnt have the picture posted when i responded btw. I was going off what little was given in the original post. I did on the otherhand just see the picture. When i was like how does he know what it looks like? LoL
Reactions: TRX2fiveO
Discussion Starter · #13 ·
Went full sent today, beat the crap out of it for 8 hours straight in 90 degree heat and by the end of the day started to puff blue smoke, gonna send it with the ebay $30 rebuild kit and probably get bigger oil cooler with a fan
Discussion Starter · #14 ·
The blue smoke appears to be karosen my special needs friend put in and after 12hours of riding i pulled the filter and boom, nothing just one singular spec of metal shaving i dont know what to think anymore
1 - 14 of 14 Posts
