Have an 02 reconES when start is fine. Go to shift...nothing. 1st gear light blinks 3 times. Any idea where to start? Was working great. Removed all plastics, and did some frame clean up. Now won't shift. WHAT HAVE I DONE??
Check and double check your connections it sounds like you might have accidently unplugged or got something wet. also if you sprayed your frame down I would unplug everything one at a time clean it blow it out get you some die-electric grease put it in the connectors and plug it back in. repeat for the next connector and the next Ect, Ect. until you have completed the whole quad. Don't forget the spark plug boot as well.
