alirght about two months ago my rancher started pouring smoke so i broke down and rebuilt it. i completly disassembled everything bottem end also and cleaned it. i had the cylinder board and new piston and rings, i did a compression test today before it was ever started and got 95 psi so cranked it up and killed it out when it was hot to touch retourqed the head bolts the took started ridding for about 5-10 mins at a time varying the rpms and noticed that is smokes when it starts getting hot is this just form the oil in the exhuast from before? its only been ran for about 25mins total also i did another compression test and got 90 psi and my spark plug is clean is this somthing i should be worried about? or will it just quit?
Thanks For any help
either you didn't do the rings and cylinder right ??.or your burning oil from your ex/muffler..oh..just because your getting 90 psi..doesn't mean your oil rings got damaged.
alright thanks im pretty sure all the ring gaps are right ill just run it and see
id bet on the rings being wrong....thats what the guy did we bought ours off of.
well unless theyv'e turned they were right when i put em in, and like i said it wont smoke until about 10 mins of ridding
huh,adjust valves?
