Hi this is my first post on the forums. I bought my first Honda last week for 800 bucks. It didn't run or roll for that matter. But I fixed the running issues and it now rolls freely. Just having shifting issues. The gear position will flash constantly it will go into gear with manual shifter I can get it to third gear. And when going to fourth it doesn't quite go in all the way. And I can shift it back down to neutral and into reverse. I put new angle sensor from Honda in it the motor seems okay jumps 12v to it after pulling it out to see if the motor turns. Cleand all connectors and nothing when you hit the buttons. I should mention the battery is fried. I was running a battery charger on it while doing this. I'm going to get a new battery tomorrow. I read somewhere a bad shift plate or shift drum possibly. I haven't tested the switch but I figured I should try a good battery first. To eliminate bad voltage. Any help would be great. Thank you
