Hey guys I could use some help.
I have a problem starting my rancher.
I turn the key on and the oil temp light stays on and it will not start.
If I flip the switch on and off until the light goes pit it will start.
Anyway I can bypass this?
Hello and welcome to the forums!..........I don't believe you should bypass it. I'm thinking it might be the switch but I could be wrong. let me do some checking around and I'll get back with you unless someone on here with more knowlege than my pea brain has let's you know first.
Does the cooling fan come on when the light is on?
