Recently picked up an 02 Foreman as a project. The 4wd light flashes 4 times
According to the service manual this is a voltage issue at the 4wd controller. The fuse for 4wd is good and I've measured the voltage at the controller on the red and green wires and get 16.6 volts. The service manual says if you have correct voltage on those wires to replace the 4wd controller. So I bought a used one off ebay and swapped it. I get the same error code with the replacement. The 4wd light flashes 4 times. Any one have any other suggestions? Other than spending the $$$'s on a new controller.
