1 - 16 of 16 Posts
Just bought a used 02 400ex, it runs through the gears fine at my house, but doesnt not idle. shuts off if no throttle. I took it to an ATV park higher elevation and while up there had no top end. it kept boggind down and backfiring. its all stock. any ideas???
X3 on cleaning the carb.
Ditto..mine did that a bit too...sticky float..been running Sea Foam in the tank and had no problems since..i recamend it highly! while your in there dont forget to blow out the pickups
Did you remove the slow jet and clean it out? that would be the main reason as to why you won't Idle, that or someone set the Idle too low.
did you blow it out too? and take a tiny piece of wire and clean out the jet orfices? the tiniest of dirt will make you pull out your hair, I gaurantee it.
Yeah, I agree. When they're real dirty it can be a pain to get them unstopped.
I've been screwing with mine for 2 weeks now off and on, I still have a hesitation spot in it, I'm jst going to buy a new carb..lol
That's Great!! glad you're up and runnning
1 - 16 of 16 Posts
