1 - 20 of 22 Posts
this is pretty simple..it involves backing the outer nut off to expose a c clip that will need to be removed after the c clip is removed the lock nut will slide off the end of the axle..then the axle will slide out the end of the carrier.
I read DirtWheels Magazine and in the Nov 2009 they have a great tech going over how to remove an axle. try
www.dirtwheelsmag.com
look through the nov 2009 issue and it will give you pics and tips
Its just a option. We should be able to help you.
1 - 20 of 22 Posts
