My start button stopped working half way through a ride today so I started rom the solenoid and fired right up. later on during the ride I wiggled the wires by by the headlight and the button started working again, but the next stop it didn't work again.
-My neutral light doesn't come on when the button doesn't work but will when the button works
-After starting the ATV the start button will start working
-Have checked the fuses and the wiring and everything seems good
I'm stumped and hoping for an idea of what to try next. Thank you for the help!
Sounds like the neutral safety switch messing up.
Try starting it with the clutch pulled in even tho the light is out and see if it starts that way.
Discussion Starter #3
I have tried staring it that way an still nothing
N/S switch is down by your right heel in the motor block.
May check that to verify it’s making good contact.
The reverse switch is there also if I’m correct.
Others may chime it to verify.
