Hey guys.
So the other day I was riding a 013 EFI 500, ran great, no problems, killed it for a couple minutes and when I fired it back up it started doing this:
With my hand off the throttle, the engine rpm is bouncing about 400 rpms up and down off idle. Basically: Rev, fall. Rev, fall. Rev fall. Continually
Give the bike a little throttle and she smooths on out, it would seem as if the EFI is trying to keep the bike from idling.
Took the air filter off and with it running I can partially block the air flow with my hand and it WILL idle smoothly.
The flap in the body is fully closing, good gas, unhooked the battery for a while, and just general inspection of the surface points no where.
What do y'all think? What should I check, I know it's gotta be a sensor, just not for sure which one does which.
