So I was riding my Trx300 and when I turned it off it wouldn’t turn back on. It turns over but has no spark, my lights still work too. (electric start) Any help will be much appreciated.
if the kill switch is centered, spark plug out of cylinder, in boot, lay it on cylinder, crank it over while watching plug, if no spark ?, check all connections on fuses, wire harness. if still no good ?, then either stator went bad ?, or c.d.i. is bad ?.
Discussion Starter #3
I put a multimeter into the two wires that plug into the coil, it reads .14 so I ordered a new coil and hopefully that’s all it is. Thank you for your help “shadetree”
Cdi box and coil check them before you go any farther
