Plasti-dip - Page 2 - Honda ATV Forum
Visual & Body Modifications Post any visual modifications you have done to your ATV vehicle here.
 16Likes
post #11 of 36 (permalink) Old 03-18-2018, 02:41 PM
_Wilson_'s Avatar
Liked: 1707 times
Update, a few members here have inquire , about plasti dip, so i did a comparison between plasti-dip bright aluminum and elastiwrap,silver bullet, and.... Thanks to @Duck0fDeath i learned plasti-dip has a new type out satin aluminum , i will be testing as rim coating, I'll update on the test soon! Thx duck!
TBRider likes this.
_Wilson_ is online now
post #12 of 36 (permalink) Old 03-18-2018, 08:07 PM
Duck0fDeath's Avatar
Liked: 264 times
I liked the idea of trying the satin aluminum because it shouldn't require using a base coat of black or any other color. I wanted as close to the original color though, and yours appears to be it. Tough to tell on a PC monitor though.
'87 TRX350D
Duck0fDeath is offline
post #13 of 36 (permalink) Old 03-18-2018, 08:37 PM
_Wilson_'s Avatar
Liked: 1707 times
Reason i went with bright aluminum, is because it needs many base coats of any color plasti dip EI, the more base coats the better. Stronger finish, and it's very very close to oem import magnesium paint , BUT. Way cheeper...... HEY man if that satin requires no base , and is a close to oem match...... I'll most likely re shoot mine, i got a can ordered.....lol , have you see the new sterling silver ? I watched a fonzie utube, the finish looks close, but your right hard to really tell from just a pic......
post #14 of 36 (permalink) Old 03-18-2018, 08:41 PM
Liked: 264 times
If you think it will benefit from additional base coats, I will do a few in black. Black is dirt cheap compared to the fancy colors. I'll definitely check out the sterling silver. I'll probably wait for you to try out the satin before I get anything. Thanks for that!
_Wilson_ likes this.
'87 TRX350D
post #15 of 36 (permalink) Old 03-18-2018, 08:57 PM
_Wilson_'s Avatar
Liked: 1707 times
According to dip you car . Com, just the true metallics requires base coats (black base is 1st choice) (thumbs up) AND you use that fade buster on any type of cured plast dip , i shot mine with a few coats, makes the finish look deeper, and makes um easier to clean the muck off, also..... Bleach white tire acid works good, but, clean mine with a water/vinegar solution and a sponge .
post #16 of 36 (permalink) Old 03-18-2018, 09:01 PM
LedFTed's Avatar
Liked: 446 times
Originally Posted by _Wilson_ View Post
plasti kote
plasti kote used to make the best engine spray-paint. after you cleaned you engine off with oven cleaner[that no longer works], you hose the cleaner off, let dry, an paint. that paint was on there! WD didnt phase it. i cant seem to find it anymore. just a side note. i have a bit left in some spray cans. its about 20 + yrs. old, it sprays spotty some now, still sticks like no other paint ive found..
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #17 of 36 (permalink) Old 03-18-2018, 09:16 PM
_Wilson_'s Avatar
Liked: 1707 times
I looked into plasti kote...... LT ......is it a rubber coating, or enamel ? I'm guessing.... Enamel for high engine block temps.
post #18 of 36 (permalink) Old 03-21-2018, 09:18 PM
_Wilson_'s Avatar
Liked: 1707 times
@Duck0fDeath , i don't think performix offers stirling silver in aerosol ? ....... At least not yet, how ever... I did find a new metallic plasti plasti-dip aluminum-A ...n yep... I Got a can coming . I have NO idea when I'll have time for testing...and a note, shooting those wheels/rims with all one color is a great idea, but.... If there's one peel , the whole coating will try to peel off, and not in just layers. Longer cures the better.
Duck0fDeath likes this.
post #19 of 36 (permalink) Old 03-22-2018, 04:07 AM
LedFTed's Avatar
Liked: 446 times
its enamel, but sticks really well. once it drys, its takes another oven cleaned to phase it. it resist heat to 500F. its not rubber, but could serve the same function as far rims are concerned. plasti-kote made some great spray paint. dont know how they are now. fast dry too
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #20 of 36 (permalink) Old 03-22-2018, 10:55 AM
_Wilson_'s Avatar
Liked: 1707 times
Thanks @LedFTed , i might have to get some and give a shot, by the way i got elasti-wrap n plasti kote mixed up, lol......
Go Back   Honda ATV Forum > Honda ATV Technical Discussions > Visual & Body Modifications
