Hey guys!
We're back on the forums! My name is Erik, and I wear many hats at SuperATV. it's been awhile, but we are trying to get more involved. Quick question..
What would you pay for a quality hydraulic rear disc brake kit?
We have an awesome front disc brake kit, but we understand the current mechanical rear kit can be a bear to adjust to your liking. The current kit is $229.95, and converting our kit to hydraulic would be more expensive. We want to know what a fair price point would be and if it would be worth converting it?
Thanks for addressing the issue most seem to have had with the existing setup, and even more so for offering a discount to members here.
I would probably go $300 if the setup would work well and the parking brake still worked.
It looks like figuring out a way to keep the Reverse lockout on a Honda would be the difficult part. The line would be cheap, but getting a left brake lever with a master cylinder that still had the Reverse lockout and parking brake would be the tough part.
It really all depends on how you do it. If the result works well, doesn't mess too much with the parking brake/ reverse function built into the left brake, I'd pay up for it.
I'm curious as to what you have in mind exactly as far as a conversion. Guys here might be able to give some input on ways to keep the functionality of the reverse lockout and parking brake when converting to hydraulic.
You could run a cable operated master cylinder like on the rear of the Rubicon/Rincon. Master cylinder itself is down by the foot brake, I think the foot brake may actually directly actuate the master cyl. Would have to look at one. Anyway, having a setup like that would allow you to keep the reverse lockout.
I think $300 would be a good target price, more than that most people probably won't be willing to pay up. I'd still like to see a wet brake setup on the rear of the SRA Hondas but that might be a bit extreme lol
I think it would be far easier to have the park brake cable operated and have the foot brake hydraulic, that said, I removed my foot brake lever and built foot boards to suit, I’m sure many others have too. Either way, your product needs to be user friendly and based on stock ATV’s in my opinion.
I’m looking forward to this as I was considering a rear disc mod.
The hydraulic kit would be worthless to me , unless SuperATV would start building a rear disc kit for a 250/350 rear end ( used in 300 mods ) , I think all it would take is a rotor hub that would fit the axle spline , which is smaller diameter than your kit works with
So I would be willing to pay for a rear disc kit that doesn't fit my bike and the parts needed to make that kit fit
Erik , right now I have 7 front disc kits ( 3 -300 4wd , 3 - 300 2wd "Super Atv 4x4 kits I modified " , 1 -450 4x4 and 1 - 450 rear disc kit ) == how's about coming up with some better brake pads
I’m doing a rear brake delete on mine. Have all the cables & foot pedal removed already. However, if Super ATV makes a rear kit, I’d be in!! The front discs I have now are awesome.
So , are you thinking about some better quality pads ? ----maybe even brass pocks ? ---- I ordered 2 sets of front pads from you'll last night , riding in the mud it is about fifty cents an hour for brakes @$25 per set of pads
Here is something I need help with right now , I have several 300 2wd Fourtrax's with the Super SuperATV disc conversion kits which I modified to fit them , I am about ready to change the front wheel bearings and seals in the hub which is supplied in the kit , can you supply bearings and seals to me or give me some numbers as there are no numbers on the bearings , I have 3 300 2wd's set up like that and would buy 3 sets from you
Pads are a tough one. Regular pads will not last as long in the mud as they would in any other condition. It doesn't matter what brand. Brass pads hold up longer in the mud, but they are terrible and unsafe in any other riding condition. I'll pass along your interest to see if something can be done when we work on the hydraulic upgrade to the rear kit.
I have most of the replacement parts you need if you want to get them from us. They are all pressed into the hubs already, so we don't have any individual bearings laying around. We can definitely get you replacement hubs if you want with the bearings already pressed into them. I can get you this week's forum code if you want to go that route and call in the order. If you'd like to find your own, they are pretty much the same as an OE replacement.
Front for the 2wd kit: 20x42x12mm (out of stock)
Rear: 58x28x16mm
I have a question on replacement parts (I sent in an email and didn't get a response).
I currently have one of your disc conversions for a 300FW. I will be ordering two more as I finish projects. On my 500's and 420 I keep extra knuckles around so that when bearings wear out I have another knuckle ready to swap in. Speeds things up a little and then I can replace bearings and ball joints when I have more time.
I asked about ordering the caliper mounting brackets (if they are available separately, and if so, what they would cost). That way I can have a set of knuckles with fresh bearings and ball joints and won't have to remove the brackets to swap the fresh knuckles on.
I've learned that on these mud and water rigs, the fewer times you have to try to remove a bolt, the less chance there is for a stripped/ broken bolt.
Can't use anti-seize on those bracket mounting bolts (really need to use locktite IMO) and those hex heads strip out easily.
Hey man!
Yeah, I definitely brought some attention to the kit. I don't have any major updates or exact eta's, but I know its been on the list. New machines and new products always end up pushing the retrofitted upgrades on the back burner...but it is in the works! Thanks for bringing it up. I'll rattle some cages. :wink
I’ll tell you what I’d like to see, an add on wet brake kit ahead of the rear differential that would act as a bolt on swing arm stretch at the same time......
If you notice , SuperATV and Highlifter both come out with kits , then when the new models come out , the older model kits get dropped = doubt we will see any new 300 , 350 , 450 kits coming out
I can see how a wet kit would cost a lot and the problem would be that every model would have to be a little different with hoses , fittings and brackets , so there would be too many variations to making kits practical -----I need to add it all up money wise , I am doing front and rear disc with hydraulics on all wheels right now and if I had to guess I got $750 plus into it , used a bunch of stuff I had , bought used masters ---- if I added labor on top of that , I would guess , if you bought a complete kit ( front and rear conversions and hydraulics ) ready to go , it would cost between $1,200-1,500 , that would include a left hand master and the front left and foot pedal plumbed together ------I think if someone where to cut the cost with the cheapest Chinese masters , tubes and hoses , and used cheap labor , it would be around a $1,000
Any updates? I have a 2000 Foreman 450ES and i bought the HL rear disc conversion kit when it was available and it is hydraulic and it's way better than the kit i bought for my 2007 Rancher 400. I am in the process of converting my Rancher over to hydraulic myself using the HL kit as a reference.
I done the rear conversion to disc , installed a left front brake lever / master cylinder assembly off a 700 Grizzly with the foot pedal master cylinder off a Honda Gold Wing , used Fragola fittings and hose , TRX250 splitter and converted it all to hydraulic disc on the front and back
