2007 honda foreman 500FM running lean - Honda ATV Forum
post #1 of 23 (permalink) Old 04-26-2015, 01:50 AM Thread Starter
jakep53's Avatar
Liked: 105 times
Sorry guys haven't posted in a very long time been too busy at school, but I need some help I am rebuilding this foreman 500 I rebuilt the topend with new timing chain piston and rings, it never ran good before i rebuilt it it would bog down cough splutter and never ran properly so a rebuilt the carb and put it on and started it today and it ran really hot and popped through the exhaust and airbox, I put the old jets back in making no difference it pops out the exhaust on deceleration and I can feel the heat from the exhaust, it has no air leaks from what I can tell and the carby has no adjustment the pilot screw tis like a half moon shape so I can't turn it and the needle has no grooves to move the clip.
anyone got an idea what I should do motor is stock no mods
here is a vid of what it sounds like (the motor is quiet its just the echo of the popping in the shed)
https://youtu.be/xjv-ZPN2e6E
atc 70, atc 90,atc 110 2x trx 250,88,89,96 trx 300, 92 &00 300 fw, atc 250
big bear 350 4x4,big bear 2x4 timberwolf 250 2x4, ytm 225dr 85 ytm 200ERN
klf 300 bayou,prairie 250, klf 185 bayou
suzuki quadrunner 250
Get your free manual here
https://www.hondaatvforums.net/forums...all-years.html
jakep53 is offline
post #2 of 23 (permalink) Old 04-26-2015, 06:16 AM
b52bombardier1's Avatar
Liked: 345 times
You could have an exhaust leak at the pipe to head union. What does a new spark plug look like after running for a few minutes? If it is bone white, your engine is running very lean.
It could also be a timing problem, especially if it is popping back through the airbox. With this situation, I would not run it hard because you are probably close to seizing a piston.
Rick
2006 Green Honda Foreman 500 - Viper Elite Winch
2004 Yellow Honda 250ex - Grandson's Bike
1971 School Bus Yellow "Spaghetti" Harley-D Sprint 350
1972 Candy Yellow Honda CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green Honda ST90 K0
1974 Mars Orange Honda CT90 K5
1975 Topaz Orange Honda ST90 K2
1976 Shiny Orange Honda CT90
b52bombardier1 is offline
post #3 of 23 (permalink) Old 04-26-2015, 08:37 AM
Liked: 1315 times
didn't sound terrible. Timing off or valve need finer adjust? did you rebuild the top end too?
Goober is offline
post #4 of 23 (permalink) Old 04-26-2015, 04:04 PM
kentco's Avatar
Liked: 1480 times
Jake, Good to hear from you again. I was wondering what happened. Good luck on the rebuild.
kentco is offline
post #5 of 23 (permalink) Old 04-27-2015, 06:06 AM Thread Starter
jakep53's Avatar
Liked: 105 times
Rick
Ill check the exhaust and check, there is a pic of the plug its white not bone white but whiter than I would like, ok I,ll check the timing out I thought I had it right but ill double check it
jakep53 is offline
post #6 of 23 (permalink) Old 04-27-2015, 06:09 AM Thread Starter
jakep53's Avatar
Liked: 105 times
I made exhaust and intake the same normally i wouldn't but the manual said the valve clearance was the same is that right? yes rebuilt the top end
jakep53 is offline
post #7 of 23 (permalink) Old 04-27-2015, 06:10 AM Thread Starter
jakep53's Avatar
Liked: 105 times
Yeah im still around schools too hard too much homework, but im stillin doin bikes, ill try to hop on more often
jakep53 is offline
post #8 of 23 (permalink) Old 04-27-2015, 08:59 AM
Official Site Vendor
nflow's Avatar
Liked: 18 times
Does is start right up or is it hard to start? www.nflowmotorsports.com
Visit our website at: www.nflowmotorsports.com
or
Like us on Facebook at: https://www.facebook.com/pages/NFLOW/237263726448384
nflow is offline
post #9 of 23 (permalink) Old 04-28-2015, 03:33 AM Thread Starter
jakep53's Avatar
Liked: 105 times
it is a little hard to start its not push of the button like my 300 I rebuilt it takes some throttle/choke
jakep53 is offline
post #10 of 23 (permalink) Old 04-28-2015, 06:09 AM Thread Starter
jakep53's Avatar
Liked: 105 times
ok correct me if i'm wrong but for me to check the timing im going to have to pull the motor right?
sorry first time doing one of these 300's are so much easier!! im gonna check the valves but im leaning towards one tooth out on the timing
jakep53 is offline
