1991 honda trx300 fourtrax 4x4 rebuild - Honda ATV Forum
 33Likes
post #1 of 28 (permalink) Old 08-02-2019, 05:09 AM Thread Starter
09z71's Avatar
Liked: 15 times
Long time lurker, first or second time poster.
I have a blue 91 4x4 trx300 that I use to hunt and do some trail riding. Recently my wife and I had twins so I figured I would be down for awhile. It's been needing a top end rebuild for awhile so i dug into it. Shipped the cylinder off to g&h and should be getting it back any day now.
I recently enough, redid the brakes. Just reran all vent tubes and will be changing all fluids when the motor is back together.
Bottom end seems tight in the motor. No real play.
So my question is, with the bike all apart as is, is there anything else I should be do?
09z71 is offline
post #2 of 28 (permalink) Old 08-02-2019, 05:25 AM
Liked: 7059 times
Blue 1st gen , love'em ! redo your head while it is apart = new valve stem seals and lap the valves , how far you go is up to you and what you might need , timing chain and sprocket might be in your stars ----- G+H will have the valve stem seals in the gasket kit , I have had nothing but good from G+H , it is what they do and you can't bet the price ---- a picture is worth a thousand words , lets see that Blue 91 300
fishfiles is offline
post #3 of 28 (permalink) Old 08-02-2019, 10:37 AM Thread Starter
09z71's Avatar
Liked: 15 times
Here it is at a friend's ranch. I really wish it had a brake light. That's my only complaint. It's been really good to me.
What are yall using for exhaust gaskets? Cooper crush sleeve? Or does something come with the g&h kit?
ID:	138800   Click image for larger version
wheeler, fishfiles and _Wilson_ like this.
09z71 is offline
post #4 of 28 (permalink) Old 08-02-2019, 02:16 PM
Liked: 7059 times
Wow , nice scenery and the atv looks good too , winch , led bar on the bars -
G+H will send you a crush washer for the exhaust --- sounds like you thinking ahead for your upper job , get some HondaBond or YamaBond for the rocker box cause there is no gasket there
you can rig up a brake light , some models sold in Maine came with brake lights , you can buy the parts from Honda any more but you could make something on the foot pedal , you can swop out the hand brake lever to one that has a brake switch in it
post #5 of 28 (permalink) Old 08-02-2019, 02:20 PM
_Wilson_'s Avatar
Liked: 1892 times
You can add a brake light, one of two ways, i did mine with a brake banjo switch, so.... My light only works with the front brakes, (cause, i almost never use my back brakes) the other way.... You'll need to ether build a wire harness, or try and locate one (extremely rare) plus the hardware (micro switches ect) i went with a single ported yooper banjo switch, because the yooper brand doesn't require much fluid pressure to work.
I think a brake light is a great idea! Mines saved me a few times hauling (on the road) firewood.
fishfiles and Goober like this.
_Wilson_ is online now
post #6 of 28 (permalink) Old 08-02-2019, 03:06 PM
Liked: 7059 times
Wilson, that is a nice Banjo switch , I never seen one before today ----being my front and rear are connected together and I have Banjo fittings at the rear of the bike , that would be a good mod for me ---- Did you modify the bulb holder to accept a double element bulb so you have running lights and brake lights ??? If so how did you pull that off ????
Goober and _Wilson_ like this.
post #7 of 28 (permalink) Old 08-02-2019, 03:09 PM
Liked: 7059 times
Fish Quote " you can buy the parts from Honda any more " Quote ------- I meant to say 'Can't " , I do that all the time with words that have not or n't behind them
post #8 of 28 (permalink) Old 08-02-2019, 03:43 PM
_Wilson_'s Avatar
Liked: 1892 times
That will work great!
Are you talking about the one jeep modded up ? 3 wedge (one tail, n two bulbs wired for brakes) bulbs in the tail light housing ?? I might try and pull that off (time permitting) but i lucked up on a hondaline brake light kit (minus the top bracket im still looking) this is an old pic, and, i believe Stanley is the brand.
fishfiles likes this.
post #9 of 28 (permalink) Old 08-02-2019, 03:59 PM
Liked: 7059 times
Ok , so you have the separate light for a brake ------------- I was thinking about using the stock tail light with a different bulb holder , is that what Jeep done ----- How did I mess Your's and Jeep's mods on the brake light ? Maybe that was one of the times my computer went down . How's about a like and a half for that one and maybe we are even now on the likes !!
My rear foot brake master has a double micro switch ( Gold Wing 1000 ) that mounts on the cylinder , never did get into that mod yet , lots of ideas , not enough time
_Wilson_ and retro like this.
post #10 of 28 (permalink) Old 08-02-2019, 05:10 PM
_Wilson_'s Avatar
Liked: 1892 times
Ya, that's what jeep did.... I looked for that thread, no luck, but here's the pic i stuck in there. And ya! I hear YOU on time limits.
Haha no 1/2 like this time. Ya, all square.
fishfiles and retro like this.
