2013 Honda Rancher ES - Honda ATV Forum
 3Likes
post #1 of 14 (permalink) Old 07-04-2019, 05:08 PM Thread Starter
strikeback24's Avatar
Unhappy 2013 Honda Rancher ES
I had run my atv for about 30 minutes brought it home and parked it. The next time I went out to ride it, it will not start. It is fuel injected. I have checked the fuses, kill switch is off, Can hear the fuel pump when I cut the switch on. The battery is strong, had it on maintenance charge and it shows 100%. It does not have but about 70 miles on it. Spark plug is also good. It turns over just will not start. Any help would be greatly appreciated.
Roy
strikeback24 is online now
post #2 of 14 (permalink) Old 07-04-2019, 05:15 PM
Liked: 3106 times
Does it have spark across a new NGK plug?
Plenty of fresh non-ethanol fuel in the tank?
Jeepwm69 and _Wilson_ like this.
post #3 of 14 (permalink) Old 07-06-2019, 12:15 PM Thread Starter
Yep Today (Saturday) just put a brand new NGK plug in it. Also has about a tank of non ethanol fuel in it. Non ethanol is all I have ever used in it.
Still doing the same thing. Motor is turning over just will not start.
Thanks,
Roy
post #4 of 14 (permalink) Old 07-06-2019, 12:38 PM
Liked: 3106 times
Ok, does it have visible spark though? Is the fuel pump starting up for a second when you turn the key on?
post #5 of 14 (permalink) Old 07-06-2019, 04:44 PM Thread Starter
When I cut the switch on I an hear the fuel pump cut on. When I put the new plug intoday I did not check for a spark since it was a brand new plug. I can say though that the old plug did not have a spark. The ATV only has 76 miles on it though.
Thanks
Roy
post #6 of 14 (permalink) Old 07-06-2019, 04:54 PM
Melatv's Avatar
Liked: 311 times
Hi: Check for spark -- you need spark
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is offline
post #7 of 14 (permalink) Old 07-06-2019, 04:58 PM Thread Starter
Where do I go if there is no spark when I check it
Thanks
Roy
post #8 of 14 (permalink) Old 07-06-2019, 07:33 PM
Liked: 3106 times
Check that the kill switch is in the "Run" position in case it got bumped accidentally. Then check the 10 amp ignition fuse inside the fuse box. Let us know how it goes.
_Wilson_ likes this.
post #9 of 14 (permalink) Old 07-07-2019, 12:25 PM Thread Starter
The kill switch is in the run position, Took the spark plug out and held against the frame and I do have a spark. I checked all the fuses and they are all good. When I turn the ignition switch to on I hear a clicking noise for a couple of seconds. I thought they may be the fuel pump but not sure. When I looked in there , there is a vertical type cyclinder with the top portion being black. We listened but the click is not from there . The click seems to be coming from some where under the seat. Still cranking but not starting. I really appreciate all you guys help.
Thanks
Roy
post #10 of 14 (permalink) Old 07-07-2019, 03:48 PM
Liked: 3106 times
The clicking is the fuel pump relay. Unplug the connector and plug it back in in case its getting a bad connection. Then bypass the relay to start the fuel pump. It shows how to do that in the service manual. If the pump still don't start up by jumpering the relay it probably needs replaced.
