2006 Foreman...won't turn off. (maybe it wants to be ridden) - Page 2 - Honda ATV Forum
 32Likes
post #11 of 36 (permalink) Old 06-24-2019, 11:02 AM Thread Starter
Liked: 3253 times
Had inlaws in town all weekend, along with 2 baby showers (I didn't go, but had to be on stand-by to load up all the gifts at the end of the showers) so didn't have a chance to do much, but I did go out and try a different ignition switch.
Still stays on.
The weird thing is, if I unhook the battery, and then hook it back up, it will stay off....for a few minutes, then suddenly the meter will power up, even with the key off.
I did pull the main fuse and that powers down the meter now. Gets weirder and weirder.
Going to pull up the wiring diagram on the FSM now to get the rest of the picture that Retro posted above.
post #12 of 36 (permalink) Old 06-24-2019, 12:01 PM
GirlsRideToo's Avatar
Liked: 447 times
Originally Posted by Jeepwm69 View Post
Originally Posted by GirlsRideToo View Post
With all that re-wiring you did on the 350 ("Starting In Gear" thread) are you sure didn't play around with this Foreman, too? Jumper wire on the starter? You've been so busy maybe you forgot.
This one is stock. Start in gear feature came from the factory, along with brake lights, so I haven't had to do any modifications to the wiring on this bike at all.
My comment was meant as a joke because you've talked about being pulled in so many different directions with everything going on in your life right now. Sorry, I should have put [joke] in my comment. LOL
I wish I was capable of helping you solve your problem. Very strange problem but I'm sure you'll figure it out!
Jeepwm69, _Wilson_ and retro like this.
GirlsRideToo is online now
post #13 of 36 (permalink) Old 06-24-2019, 12:19 PM
Liked: 3156 times
I'd try unplugging the regulator/rectifier next.
Jeepwm69 and _Wilson_ like this.
post #14 of 36 (permalink) Old 06-24-2019, 12:38 PM
Liked: 447 times
I found this post on the Foreman forum and it might be helpful to you related to possible wiring to test. Wiring diagrams are a nightmare for me. Hope this helps you in some small way.
https://www.hondaforeman.com/130-for...witch-off.html
post #15 of 36 (permalink) Old 06-24-2019, 07:49 PM
LedFTed's Avatar
Liked: 465 times
sticky relay, bad off switch, including ignition switch, bad diode, accessory feedback, faulty ground. .25 cents worth.
Jeepwm69 and misterclean59 like this.
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #16 of 36 (permalink) Old 06-25-2019, 04:55 AM
Liked: 6793 times
If I had to guess, I would think it is inside the controller ---- do you keep it outside , did it rain lately
fishfiles is offline
post #17 of 36 (permalink) Old 06-25-2019, 08:23 AM Thread Starter
Liked: 3253 times
Winch controller? When I first noticed it it hadn't rained in a couple of weeks.
post #18 of 36 (permalink) Old 06-25-2019, 08:36 AM
wheeler's Avatar
Liked: 454 times
IF you are pulling the main fuse & it is still powered up, you have to have a hot wire downstream of the fuse making a connection. ONLY way I can logically see it still having power....
misterclean59 likes this.
1995 Honda 300, 355bbk, 40b Webcam, Springs & Hardened Rockers, 300ex Carb, Ricks CDI, FMF Full Exhaust, EBC DRC Clutch Kit, Outlaw Clutch Springs, Twin Air Filter, HL Disc Brake Conversion, Wide Open 424 kit, HL 2" lift, Bronco Shocks, 26" Zillas, Terra 35 Super Winch, Heat Demon Hand/Thumb Warmers, Powermadd Hand Guards, PIAA 35w Bulbs
wheeler is online now
post #19 of 36 (permalink) Old 06-25-2019, 10:31 AM Thread Starter
Liked: 3253 times
Well it did that at first, but now when I pull the fuse the display shuts off.
I DID unhook the winch contactor after I tried pulling the main fuse when the display stayed on, so possible I had more than one issue.
post #20 of 36 (permalink) Old 06-25-2019, 10:37 AM
wheeler's Avatar
Liked: 454 times
So u r thinking the winch connection may be culprit? Makes sense...
