Help honda Rincon 650 issues - Honda ATV Forum
 3Likes
post #1 of 16 (permalink) Old 04-21-2019, 09:49 PM Thread Starter
Overloaded's Avatar
2003 650 rincon with 2962 miles and 582 hrs. The issue was the cam chain. I put new guides, chain and tensioner. I did not do the oil pump & chain like I should have while I was in there. Got it back together she started right up. Did a test ride down the road it shifts fine and speedometer works. Got back in and finished putting my plastic covers on. The next weekend I go out on a trail ride and I have no speedometer and it’s not shifting in either auto or esp. 4wd works and I’m not getting any codes. I did find my front axle shaft popped out of the diff. I’m pretty sure my front diff has mud and water in it by now but I doubt that’s my issue. I’ve taken the transmission valve body off, took it apart cleaned it good, cleaned the connectors for the solenoids didn’t find any junk in there. bought a new AGM battery. My rincon runs good but dies after a 10-15 minutes of riding. It is burning oil under a load and on a cold start. Only mods I have is a home made snorkel and 26’s
Any help is greatly appreciated.
Overloaded is offline
post #2 of 16 (permalink) Old 04-21-2019, 11:20 PM
Liked: 2766 times
You can get a copy of the service manual in the manuals forum if you don't have one yet and rebuild it.
https://www.hondaatvforums.net/forum...downloads.html
post #3 of 16 (permalink) Old 04-22-2019, 07:04 AM Thread Starter
Overloaded's Avatar
I appreciate it. I’ve already got a copy.
post #4 of 16 (permalink) Old 04-22-2019, 09:44 AM
Liked: 2936 times
Originally Posted by Overloaded View Post
2003 650 rincon with 2962 miles and 582 hrs. The issue was the cam chain. I put new guides, chain and tensioner. I did not do the oil pump & chain like I should have while I was in there. Got it back together she started right up. Did a test ride down the road it shifts fine and speedometer works. Got back in and finished putting my plastic covers on. The next weekend I go out on a trail ride and I have no speedometer and itís not shifting in either auto or esp. 4wd works and Iím not getting any codes. I did find my front axle shaft popped out of the diff. Iím pretty sure my front diff has mud and water in it by now but I doubt thatís my issue. Iíve taken the transmission valve body off, took it apart cleaned it good, cleaned the connectors for the solenoids didnít find any junk in there. bought a new AGM battery. My rincon runs good but dies after a 10-15 minutes of riding. It is burning oil under a load and on a cold start. Only mods I have is a home made snorkel and 26ís
My guess is one of your speed sensors is shot, and that's keeping it from shifting. The Rincon has to know how fast it's going to shift.
Dying after a few minutes of riding....check the vent on your gas tank. Take the cap off your tank next time it does it and see if it starts. You also need to make sure your petcock isn't partially clogged.
The oil burning sounds like it's just worn out. It will likely get worse with use. Cold starts only is usually valve stem seals. Under a load means worn rings/cylinder.
retro likes this.
post #5 of 16 (permalink) Old 04-22-2019, 10:31 AM Thread Starter
Overloaded's Avatar
I’ll be gettin another 650 rincon this weekend on a trade so the first thing Im gonna do is swapping the speed sensors
post #6 of 16 (permalink) Old 04-22-2019, 03:43 PM Thread Starter
Overloaded's Avatar
Quick update! Here’s what my front diff looked like when I drained it... this was about 5 mins after pulling the plug. No metal in the oil just thick muck. Is it possible that the speed sensors are just filthy? Maybe a good cleaning would do the trick?
post #7 of 16 (permalink) Old 04-22-2019, 04:45 PM
Liked: 4207 times
if you keep treating it like a boat ?, no matter how many times you drain the diff's ?, it won't last long. I see a motor tear down coming, and it will not be as cheap as that speed sensor :-).
post #8 of 16 (permalink) Old 04-22-2019, 05:31 PM Thread Starter
Overloaded's Avatar
if you keep treating it like a boat ?, no matter how many times you drain the diff's ?, it won't last long. I see a motor tear down coming, and it will not be as cheap as that speed sensor 🙂.
I don’t treat it like a boat, my buddy I got it from sunk it above the seat before I got it.
post #9 of 16 (permalink) Old 04-22-2019, 09:01 PM
Liked: 2766 times
If its got a lift kit on it you might have to lower the lift an inch or so to keep that axle from popping out of the front diff.
post #10 of 16 (permalink) Old 04-22-2019, 10:11 PM Thread Starter
Overloaded's Avatar
No lift. I have no idea why it popped out.. maybe i wiggled it loose when I had to unbolt the diff to get the front cover off
2000 TRX450FM Build/Mods fishfiles Builds, Projects & DIY 1043 05-05-2019 03:52 AM
Ongoing project, 300 fourtrax. SamUK Builds, Projects & DIY 619 06-28-2018 01:44 PM
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
