1993 Honda Fourtrax 300 4x4 - Page 2 - Honda ATV Forum
 32Likes
post #11 of 72 (permalink) Old 04-21-2019, 12:00 AM Thread Starter
MrC.'s Avatar
More of the same, The more it runs the better it sounds.
Shadetree may be right again, the binding is coming from the rear diff, the t-case and front diff, I changed fluid and they feel fine, So what are my options? replace bearings in the rear diff? replace ring and pinion? or swap the entire unit? Can I do it? basic hand tools?
I Cleaned the brakes (waiting on brake lever now) Spent two hours cleaning the tank, installed a fuel filter to be safe. I found some aluminum factory rhino wheels 7.5x12 and 6x12 4x110 pattern those and some matching tires should bring this pig into the 21st century looks wise. I will upload a pic of the plastics, they are a mess. I really don't know what to do about them.
The whirling noise has stopped, after the first couple starts it went away, may be it needed to be ran, sitting 5 years may have gotten a little stiff. While on jack stands and running, I shifted through all the gears and even into reverse, all gears works fine no issues (at least with no load on them).
Lets see what tomorrow brings. I want to see it on the ground and moving under its own power!
MrC.
MrC. is offline
post #12 of 72 (permalink) Old 04-21-2019, 07:42 AM
Liked: 4279 times
changing the ring gear and pinion gear in the rear diff is not too hard ?, the worst part is replacing the pinion needle bearing !. it wont' be easy to get the old pinion needle bearing out, but it can be done !.
post #13 of 72 (permalink) Old 04-21-2019, 06:47 PM Thread Starter
MrC.'s Avatar
So today has been fun, I scored some aluminum wheels and some new take off 25in tall tires.
Found a guy on eBay, who rebuilds the rear diffs for $185 and that includes a warranty and free return shipping.
Also talked to the guy in Arkansas who has new plastics, we are working on what shipping through fastenal might be for a full set.
fingers crossed on that. locally I get get some used plastics from a junk yard but there then there 26 years old.
I ran through all the gears and reverse all the dash lights work as they should and the headlight switch is working along with high and low, the bulbs are toast.
So now it comes down to plastics, rear diff, and a leaky front driveshaft seal (t-case side), it didn't start leaking until after I changed the fluid. lol.
Below you will see the new wheels, I may keep these they weight almost nothing, the terrible state of the plastics and the new knobby tires 25in on the left side of my v treads.
Enjoy the photos
MrC.
ID:	135876   Click image for larger version
ID:	135878   Click image for larger version
ID:	135880   Click image for larger version
ID:	135882   Click image for larger version
MrC. is offline
post #14 of 72 (permalink) Old 04-21-2019, 06:49 PM Thread Starter
MrC.'s Avatar
new tires
These are new factory take offs from a John deere side by side, I will be selling the wheels asap, I just wanted the tires. rand new and cheap.
the V treads are the cheapest tire on Amazon, they say they as 26 inches tall, the knobbys say there 25 inches tall. someones lying.
MrC.
ID:	135886   Click image for larger version
MrC. is offline
post #15 of 72 (permalink) Old 04-21-2019, 08:55 PM Thread Starter
MrC.'s Avatar
Parts
I can not find the seal part number anywhere for the front output drive shaft of the transfercase.
Also would any other fender set or model would fit my 93 trx300. something newer? something cheaper?
MrC.
MrC. is offline
post #16 of 72 (permalink) Old 04-21-2019, 09:31 PM
_Wilson_'s Avatar
Liked: 1803 times
_Wilson_ is offline
post #17 of 72 (permalink) Old 04-22-2019, 04:46 AM Thread Starter
MrC.'s Avatar
Thanks WIlson
Partzilla didn't list it. Thank you.
I feel like there should be a 6ft privacy fence between us. Lol
Thanks again
MrC.
_Wilson_ likes this.
MrC. is offline
post #18 of 72 (permalink) Old 04-22-2019, 07:29 AM
Liked: 4279 times
Thanks again
MrC.
it was listed under the drive shaft on partzilla, just like everything else, they are removing parts for the trx300's slowly one part at a time, wont be long, and all parts for them will not be around.
post #19 of 72 (permalink) Old 04-22-2019, 09:38 AM
Liked: 3240 times
Originally Posted by Goober View Post
Nice project C! I like to work on stuff but I don’t like to sell it lol.
Jeep what’s the frame diff—advantages for builds mebbe? I have a 93 with i think a single frame pipe running under the tank. It has a fan, too.
Well the first gens are harder to find parts for, and you can't use a Wide Open 424 on them without modifying it to fit because nobody makes a 424 for the first gens anymore.
I'm not sure if there's a benefit for the actual first gen frames in the mud, but some people seem to prefer the 1st gen bikes for mud bikes. The 88's had a BR cam in them from the factory, but I don't think any of the other 1st gens did, but I do think the 1st gen CDI's allowed for more RPM's.
@mac102004 could probably either verify what I've said, or tell me I'm wrong on every point.
post #20 of 72 (permalink) Old 04-23-2019, 06:46 AM
_Wilson_'s Avatar
Liked: 1803 times
Thanks again
MrC.
Glad to help.
@MrC PM coming soon!
_Wilson_ is offline
2000 TRX450FM Build/Mods fishfiles Builds, Projects & DIY 1083 06-14-2019 12:13 PM
Handlebars Moparman318360 Honda Rancher 6 12-05-2018 04:45 AM
Ongoing project, 300 fourtrax. SamUK Builds, Projects & DIY 619 06-28-2018 01:44 PM
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
