2006 rubicon no spark no neutral light - Honda ATV Forum
 4Likes
post #1 of 34 (permalink) Old 04-04-2019, 02:09 PM Thread Starter
Jody78's Avatar
Hello I am working on a 2006 Rubicon for a friend. The motor started giving trouble shifting and he was getting a temp warning light. When he shut the bike off it would not turn or pull over. I ended up removing the motor and completely dismantling it to find a 5mm bolt stuck in the oil pump. The bolt came from a divider inside the oil tank. Replaced the oil pump and put the engine back in.
Tried starting the engine today and no spark and the gear position does not read on the dash.
Looking for some help. Should the coil still spark without the neutral light being on
Jody78 is offline
post #2 of 34 (permalink) Old 04-04-2019, 02:58 PM
Liked: 2864 times
Won't get spark if it can't tell what gear it's in.
So nothing at all on the gear position on the dash?
post #3 of 34 (permalink) Old 04-04-2019, 04:26 PM Thread Starter
Jody78's Avatar
No just the broken lines. And no code blinking
Jody78 is offline
post #4 of 34 (permalink) Old 04-04-2019, 04:38 PM
Liked: 4086 times
without a neutral light ?, it won't fire the spark plug at all.
post #5 of 34 (permalink) Old 04-04-2019, 05:12 PM Thread Starter
Jody78's Avatar
Any idea how to trick the gear position sensor
Jody78 is offline
post #6 of 34 (permalink) Old 04-04-2019, 05:52 PM
Liked: 4086 times
why not just find the problem, and fix it the correct way ?.
post #7 of 34 (permalink) Old 04-04-2019, 05:57 PM Thread Starter
Jody78's Avatar
Any suggestions?
Jody78 is offline
post #8 of 34 (permalink) Old 04-04-2019, 06:38 PM
Liked: 4086 times
Any suggestions?
yeah, down load the service manual, dig in ! :-).
post #9 of 34 (permalink) Old 04-04-2019, 07:24 PM Thread Starter
Jody78's Avatar
Jumped out the neutral switch and it’s now running. Now I need to pull the switch to check it out.
Jeepwm69 likes this.
Jody78 is offline
post #10 of 34 (permalink) Old 04-05-2019, 09:25 AM
Liked: 2864 times
Did you download the FSM? It will have directions on ohming out the gear position switch.
If I recall correctly there are 2 switches on the shifter as well on the Rubicon.
No spark or neutral light Tedhilton2004 Honda Rancher 1 02-13-2019 09:03 AM
2006 TRX500 FE problem shifting back to neutral jcoon356 Repair & Maintenance 4 02-07-2019 10:45 AM
No Neutral Light...04 400EX Hutch215 Repair & Maintenance 3 12-29-2018 06:44 PM
Recon neutral light - between 3rd and 4th gear one1 Honda FourTrax 22 05-29-2017 11:45 PM
Trx 90 and trx 250 neutral light faults? Help! Stavros Repair & Maintenance 2 09-14-2016 09:14 AM
