2007 rancher wont start - Honda ATV Forum
post #1 of 18 (permalink) Old 03-24-2019, 01:51 PM Thread Starter
Benji1213's Avatar
Working on a friends 07 420 rancher. It has set for along time. We have cleaned the tank replaced fuel pump fuel injector and fuel filter. Im getting fire with the a new plug and getting a good spray out of the injector. It will hit it just wont keep running if it does start. When i replaced the fuel pump we cleaned the canister and filled it half way with gas so it wouldnt have to work so hard on pumping full of fuel. I have never worked on a fuel injected bike before. So any suggestions or help is appreciated! Im learning about these things!
Benji1213 is offline
post #2 of 18 (permalink) Old 03-24-2019, 01:59 PM
Liked: 4077 times
is the fuel pump running all the time ?, if my memory is any good ? ( thats says a lot !..lol ) these models have a fuel pump relay to kick the pump on and off. plenty of fuel in the tank ?, petcock set to right position ?, fuel lines from pump to injector hooked up right ?. there is also a sensor in the air box I think ?, it works with the throttle body if I remember right ?.
post #3 of 18 (permalink) Old 03-24-2019, 02:43 PM Thread Starter
Benji1213's Avatar
Plenty of gas,new pitcock i have tried it on reserve and on nothing changes. I turn the key on it hums then turns off as usual.its getting fuel to the injector. Had it out but pluged up and it shot a good fan of gas. Didnt notice a sensor in the sir box but ill look.
post #4 of 18 (permalink) Old 03-24-2019, 02:59 PM Thread Starter
Benji1213's Avatar
Does have a sensor in the air box. Im waiting on a air flter. But i did notice it would try and start better with the box closed up! Would not having the filter on it affect it running? I think its a fuel issue because it will on starting fluid whic i hat using!
post #5 of 18 (permalink) Old 03-24-2019, 04:12 PM
Liked: 2603 times
The sensor in the airbox must be plugged in or it won't start. Try replacing the spark plug with a new NGK as well. If you put a Champion plug in it it will fail right away, they're junk.
post #6 of 18 (permalink) Old 03-24-2019, 05:01 PM Thread Starter
Benji1213's Avatar
Sensor is plugged in. It has a ngk plug which is brand new.
post #7 of 18 (permalink) Old 03-24-2019, 05:35 PM
Liked: 4077 times
put the air filter back in, close lid, see how it does ?.
post #8 of 18 (permalink) Old 03-24-2019, 06:38 PM Thread Starter
Benji1213's Avatar
He is supposed to bring me the air filter. All I have is screen part. The element was rotten.
post #9 of 18 (permalink) Old 03-25-2019, 09:45 AM Thread Starter
Benji1213's Avatar
Air filter is on. It wants to run it just won't! Acts like it's starving for fuel.
post #10 of 18 (permalink) Old 03-25-2019, 11:21 AM Thread Starter
Benji1213's Avatar
Filter in. Tries to start still no go. Acts like it's starving for fuel.
2007 honda rancher 420fm wont start, spark plug is dry Michael Hubbard Honda Rancher 5 07-07-2018 03:03 PM
2007 rancher 420fm wont start k2knobloch Repair & Maintenance 14 01-28-2018 01:44 PM
Honda 2007 Rancher Will Crank Won't Start Helppp!!!!! LukeMoody Repair & Maintenance 12 02-08-2017 11:17 AM
2007 TRX420TM/FM Fourtrax Rancher wont start Yotis Honda Rancher 12 11-22-2016 05:43 PM
2007 Rancher 420 Won't start Help LukeMoody Repair & Maintenance 5 04-14-2016 09:39 AM
