2014 Honda foreman overheating - Honda ATV Forum
 2Likes
post #1 of 12 (permalink) Old 02-12-2019, 09:47 PM Thread Starter
Bradmiller's Avatar
I have a 2014 Honda foreman and within about 15 minutes of riding it'll start to over heat. I have the radiator relocated . I've replaced the thermostat and cleaned the radiator until it's clean as a whistle. I also checked the water pump on it, it seemed to be fine all the props were still in tack and is wasn't seized up . The fan comes on and will run pretty much the whole time. I did notice the hose coming out the top of the radiator will get hot and the hose on the bottom would be much cooler . I don't know what else to check . Anyone have any ideas . Thanks
Bradmiller is offline
post #2 of 12 (permalink) Old 02-12-2019, 10:33 PM
GirlsRideToo's Avatar
Liked: 386 times
Was the new thermostat OEM?? If not, I would pull it out and check it per the manual. Actually, even if it is OEM I would pull it out. Sounds like it may be sticking in the closed position.
I'm assuming you used the correct size tubing when you relocated the radiator?
Did you bleed the system well after you relocated, refilled the radiator and reserve tank? Air in the system will cause overheating.
GirlsRideToo is offline
post #3 of 12 (permalink) Old 02-13-2019, 06:16 AM Thread Starter
Bradmiller's Avatar
Yes the thermostat was OEM . All the hoses came with relocate . How do I check for air in the system ?
post #4 of 12 (permalink) Old 02-13-2019, 07:02 AM
ktriebol's Avatar
Liked: 123 times
I'm not familiar with that particular thermostat, but can it be installed upside down?
2015 TRX500 Foreman
ktriebol is offline
post #5 of 12 (permalink) Old 02-13-2019, 09:32 AM Thread Starter
Bradmiller's Avatar
No it has a flat lip around the top where it sits in. Anyone know how to check for water in the system?
post #6 of 12 (permalink) Old 02-13-2019, 11:26 AM
ktriebol's Avatar
Liked: 123 times
Maybe thermostat is defective. Try running without it.
2015 TRX500 Foreman
ktriebol is offline
post #7 of 12 (permalink) Old 02-13-2019, 12:37 PM Thread Starter
Bradmiller's Avatar
I've tried running it with out and still had the same problem I put a new one in on Monday and still no luck.
post #8 of 12 (permalink) Old 02-13-2019, 02:35 PM
TBRider's Avatar
Liked: 214 times
Have you idled the bike with the rad cap cracked?
_Wilson_ likes this.
2017 Rubicon TRX500FM6
2500 lb KFI winch and KFI mount
VIP Flare windshield with mirrors
26" Maxxis Bighorns
72W 9" LED light bar
Heated handlebars and thumb warmer
K&N Oil filter
TBRider is offline
post #9 of 12 (permalink) Old 02-13-2019, 08:46 PM Thread Starter
Bradmiller's Avatar
I haven’t tried it with the cap cracked I will try that out tomorrow. Thanks
post #10 of 12 (permalink) Old 02-13-2019, 09:22 PM
Liked: 386 times
You bleed the air by:
Fill the radiator with coolant up to the filler neck. Leave the cap OFF
Be sure quad is in Neutral
Start engine and let it idle 2-3 minutes
Snap the throttle 3-4 times to bleed air from the system. You may see a little coolant "burp" from the radiator, but you may not.
Turn the engine OFF and add coolant back up to the filler neck of the radiator (the level should have gone down slightly as the coolant circulates and air is removed)
Install the radiator cap
This is why @TBRider suggested to try letting the quad idle with radiator cap off.
Keep us posted, please.
clutch kit and gear reduction question mudking16 Honda Rancher 19 12-13-2017 07:57 PM
2013 or 2014 Honda Foreman 500 Darklight ATV Purchasing and Price 38 09-16-2017 10:15 PM
2014 Honda Foreman ES EPS price check slaterancher ATV Purchasing and Price 0 06-19-2017 07:25 AM
