Last ditch post for my 98 450ES not running - Page 3 - Honda ATV Forum
 112Likes
post #21 of 277 (permalink) Old 01-13-2019, 01:15 PM
Liked: 3221 times
Are you putting new NGK spark plugs in it? Champion don't work.
post #22 of 277 (permalink) Old 01-13-2019, 01:57 PM Thread Starter
bcsman's Avatar
Liked: 223 times
Yes made sure of that..
1998 Honda Foreman 450ES
bcsman is offline
post #23 of 277 (permalink) Old 01-13-2019, 02:39 PM
ktriebol's Avatar
Liked: 124 times
4) @ktriebol--did check valves yesterday and with T lined up on compression pretty much had .006 on both valves
bcsman, I saw that you checked valve clearance in your earlier post. I wasn't referring to that when I asked you if you were sure that the valve timing is correct. What I mean by correct valve timing is that the camshaft must be timed correctly to the crankshaft. If the timing chain is off one or more teeth, the valve timing is incorrect. Correct setting of valve timing is explained in the service manual.
wheeler, LedFTed and Chalkymon like this.
2015 TRX500 Foreman
ktriebol is offline
post #24 of 277 (permalink) Old 01-13-2019, 04:20 PM Thread Starter
bcsman's Avatar
Liked: 223 times
Oh sorry no I haven't checked that, I think I need to tear more of the engine apart to check.
Chalkymon likes this.
bcsman is offline
post #25 of 277 (permalink) Old 01-13-2019, 04:41 PM
wheeler's Avatar
Liked: 486 times
I had my cam chain off 1 tooth. Quad ran but never right. Once I fixed it it was a new machine. So if that’s off your .006 will not really be that at TDC...
1995 Honda 300, 355bbk, 40b Webcam, Springs & Hardened Rockers, 300ex Carb, Ricks CDI, FMF Full Exhaust, EBC DRC Clutch Kit, Outlaw Clutch Springs, Twin Air Filter, HL Disc Brake Conversion, Wide Open 424 kit, HL 2" lift, Bronco Shocks, 26" Zillas, Terra 35 Super Winch, Heat Demon Hand/Thumb Warmers, Powermadd Hand Guards, PIAA 35w Bulbs
wheeler is offline
post #26 of 277 (permalink) Old 01-13-2019, 04:47 PM
LedFTed's Avatar
Liked: 488 times
Originally Posted by Goober View Post
classic CDI failure
Ok if it was me Iíd pull the CDI and bake it in the oven at no more than 180F for at least two hours. Let it cool completely!!! then reinstall. Donít rush the cool down.
Goober;; first i ever heard of this remedy. does the age of atv matter,[i.e. CDI], when trying this?
bcsman:: : when did you first post? my memory is some short, and i want too reread, what you wrote first, before i suggest anything.
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #27 of 277 (permalink) Old 01-13-2019, 06:33 PM Thread Starter
bcsman's Avatar
Liked: 223 times
Originally Posted by LedFTed View Post
classic CDI failure
Oh good grief are you sure you want to reread, they have rambled all over the place. But here you go, good luck...
Dec 17-Foreman forum
Jan 8--Repair forum
Jan 11--Repair forum
This post
bcsman is offline
post #28 of 277 (permalink) Old 01-13-2019, 07:08 PM
LedFTed's Avatar
Liked: 488 times
Originally Posted by bcsman View Post
classic CDI failure
Ok if it was me I’d pull the CDI and bake it in the oven at no more than 180F for at least two hours. Let it cool completely!!! then reinstall. Don’t rush the cool down.
Jan 8--Repair forum
This post
Dec 17 works for me. if it were in one thread instead of many, i would have better luck, keeping up. after 4 strokes, sometimes i cant remember what i was thinking, just before i stand up. Patience is required for us the Old ones, Patience must be learned, by the young, or those that have not acquired it... just a thing
2000 450es TRX
2 grass hog 4x4s
sum humor adds up
LedFTed is offline
post #29 of 277 (permalink) Old 01-13-2019, 09:19 PM Thread Starter
bcsman's Avatar
Liked: 223 times
Ya should have kept to one, my bad...
LedFTed likes this.
bcsman is offline
post #30 of 277 (permalink) Old 01-13-2019, 09:29 PM
GirlsRideToo's Avatar
Liked: 514 times
I'm going out on a major limb here so I hope you'll take my comments in the spirit in which they are offered.
I read back through all your threads to be sure I understand where you are at this point. I know you listed, in this thread, what you've done so far, but that still does not sort it out in my simple brain. Here are my questions:
1. You added a new fuel line without a filter. Are you sure the fuel line is the correct size per the manual?
2. After adding the new fuel line did you fill the tank adequately to check the fuel flow in both the On and Reserve positions? I don't see where you were ever able to get good flow in "On". Maybe you did and did not post about it.
3. You say there is no problem with the fuel flow from the tank to the carb but you are basing this only on the fact that the plug is wet and, I think, you said you had fuel in the bowl of the carb on one occasion. This only proves fuel got to the carb at some point but doesn't mean you have a good constant flow.
Also, you said you thought fuel flow was good because you blew air through the petcock. Sorry, but air from the outside into the tank may just push any debris back into the tank and it will settle again against the petcock filter. AND, that petcock filter just slides on and you may have knocked it off when you flew air through it.
4. Are you positive your fuel selection knob is in "ON' and not Reserve or somewhere in between. My On position is about 1/2 inch past the On position. You mentioned several times that you did not have much fuel in the tank. Are you cheaping out because you don't want to waste fuel? LOL. Fill that puppy up at least 1/3 of a tank. You'd be amazed how much gas needs to be in the tank to crank it.
4. As @shadetree mentioned, be sure you gas cap is sealing and that the vent tube is not stopped up.
I'll throw in #5 for the entertainment value. Part of my job here is to make you laugh.
5. Are you sure, really sure, the kill switch is off. Flip that switch back and fourth a few times and be sure it comes to rest in the centered position. It's fooled me more than once.
Sorry for asking all these things but I can't get past the fuel delivery issue. I hate to see you trying all these things when you may not need to.
Goober, Z7What and Chalkymon like this.
GirlsRideToo is offline
