86 trx350A clutch replacement - Honda ATV Forum
 30Likes
post #1 of 67 (permalink) Old 08-26-2018, 05:50 PM Thread Starter
86_4trax4x4's Avatar
Liked: 13 times
Hi guys and gals! Thanks for the join. I have an 1986 trx350a looking for some advice and know how. So last weekend i was riding and got in to deep in a water crossing and swamped my bike. I've changed all fluids and flushed the motor a few times before putting rotella and a new filter in. Now comes my issue. Went on a nice 50 mile ride yesterday and noticed when i would shift from 2-3 or 3-4 if i was getting on it hard it would slip unless i let off it then i could get back in to it. Does anyone think that i should go ahead and replace the clutches and go from there? Any specific clutches people are running? Any insight on special tools or things i should know before attempting this job? I also have found that every where shows the 300 and 350 share same clutches? Is that true? Should i go with a heavy duty clutch kit since im running 27s? Thanks!!
ID:	128524   Click image for larger version
ID:	128526   Click image for larger version
Goober likes this.
86_4trax4x4 is offline
post #2 of 67 (permalink) Old 08-26-2018, 06:25 PM
Liked: 3154 times
Try adjusting the clutch first. If it still slips you might want to put an EBC DRC clutch kit (complete with springs) in it.
Goober and SamUK like this.
post #3 of 67 (permalink) Old 08-27-2018, 12:37 AM
SamUK's Avatar
Liked: 2034 times
I ran EBC HD clutches in my 300 with new OEM springs, the spring rating of the HD clutch kit was ridiculous IMO so I opted for the new OEM springs which have caused no issues what so ever. I would certainly try adjusting before replacing though.
When you flushed the engine did you spin the wheels and go through the gears at all? It may be worth while dropping your oil and looking for contamination now you’ve ridden it.
I used to change all oils after every two outings (300 was a mud bike), even though everything was sealed the best it possibly could be contamination was still noticeable in ALL oils. In your case you may have fluid (whatever you used to flush or crud from being swamped) trapped between clutch plates.
Goober and Chalkymon like this.
98 300 Fourtrax 4x4
2004 Foreman 450S
SamUK is offline
post #4 of 67 (permalink) Old 08-27-2018, 05:48 AM Thread Starter
Liked: 13 times
Ok. Thanks for the quick replies. I did run it after the flush. I filled it up started it and cycled thru the gears. I drove it once enough to load on my truck then off. I did try adjusting but it didnt make a difference. Do you know if the 300 clutch is the same? From what I can see they call for same number. As far as springs were they to stiff??
post #5 of 67 (permalink) Old 08-27-2018, 07:36 AM
SamUK's Avatar
Liked: 2034 times
I don’t know if 300 clutches are the same, it’s been a long time since I looked in a 350 and I haven’t checked part numbers out, email EBC and they should provide you with the correct part number, their a helpful bunch. I never tried the springs in the bike, they were noticeably stronger when I compressed them by hand and I didn’t want stronger springs. I’m not saying it’s a bad thing I just wanted OEM.
98 300 Fourtrax 4x4
2004 Foreman 450S
SamUK is offline
post #6 of 67 (permalink) Old 08-27-2018, 08:47 AM Thread Starter
Liked: 13 times
Thanks for the help!! I'll shoot them an email and see what they say. Im ok with heavier springs since im a sportier type rider and play mud too.
SamUK likes this.
post #7 of 67 (permalink) Old 08-27-2018, 10:04 AM Thread Starter
Liked: 13 times
So i did some research along with emailing ebc. The factory part numbers for the clutch plates both steel and friction are the same between my 86 and a 90 trx300 fourtrax. So with that being said i am to believe that a heavy duty 300 kit would also be a heavy duty kit for my 350. Any one recommend a gear reduction kit while im in there?
Goober likes this.
post #8 of 67 (permalink) Old 08-27-2018, 10:45 AM
Liked: 3249 times
https://www.hondaforeman.com/157-vin...ml#post2715697
@mac102004
Where has mac been lately? He's been quiet.
_Wilson_ and SamUK like this.
post #9 of 67 (permalink) Old 08-27-2018, 11:01 AM
SamUK's Avatar
Liked: 2034 times
For a GR get in touch with Jeremy Lee at Reduction Boss, you’ll find him on FB, or Ron Shaw would be able to help you out, again you’ll find him on FB or from anquick google search.
Yes, where is mac102004 ?
_Wilson_ likes this.
98 300 Fourtrax 4x4
2004 Foreman 450S
SamUK is offline
post #10 of 67 (permalink) Old 08-27-2018, 05:06 PM Thread Starter
Liked: 13 times
Thanks for the replies. I found one on ebay that's supposed to be a drop in kit. 200 for kit minus 75 dollar core. So 125 for both gears.
