Start in gear, late 300's and 350 Ranchers - Page 10 - Honda ATV Forum
 45Likes
post #91 of 104 (permalink) Old 04-27-2019, 08:19 PM Thread Starter
Liked: 3240 times
Ah! That makes sense. Ground to power blows fuses doesn’t it!
retro likes this.
post #92 of 104 (permalink) Old 04-27-2019, 08:27 PM
Liked: 3154 times
Well, we mustn't mention anything about that... :-)
post #93 of 104 (permalink) Old 04-27-2019, 08:30 PM Thread Starter
Liked: 3240 times
Thanks for the help! I’ll get it fixed after church tomorrow.
Sometimes the simplest stuff throws me for a loop!
post #94 of 104 (permalink) Old 04-27-2019, 08:41 PM
Liked: 3154 times
Me too! :-)
post #95 of 104 (permalink) Old 04-28-2019, 07:47 AM Thread Starter
Liked: 3240 times
Got the wires swapped around, and it will now crank over with brake lever held, but not getting spark.
It acts like a 300 does with the kill switch off. Turns over fine bit no spark.
Starts fine in Neutral. Any ideas?
post #96 of 104 (permalink) Old 04-28-2019, 09:03 AM Thread Starter
Liked: 3240 times
Ran a jumper from battery negative to connection where 30 attaches to harness, which allowed for neutral light to come on (backfeed) and still no start.
Now I’m really confused. Still starts fine when it’s actually in Neutral
post #97 of 104 (permalink) Old 04-28-2019, 05:24 PM Thread Starter
Liked: 3240 times
Ran a jumper from the 30 terminal to the light green wire on the CDI and that got it! Starts in gear now with the brake lever pulled.
retro likes this.
post #98 of 104 (permalink) Old 04-28-2019, 09:00 PM
Liked: 3154 times
Sorry I didn't respond earlier Jeep, I was outdoors wrenching all day! I missed that light green going to the CDI from the neutral switch yesterday. Just looked at the wiring diagram before logging on and now I feel pretty dumb... :-(
Glad ya found it and got it going though!
Jeepwm69 likes this.
post #99 of 104 (permalink) Old 06-14-2019, 02:05 PM Thread Starter
Liked: 3240 times
I had @PowerStroke70 ask me where this thread was, so here it is.
To summarize on the 300
Get your relay.
Ground wire (under frame bolt) to Foreman brake micro switch
Other side of micro switch to relay 85
Ground relay 87
12v pos switched power source to relay 86 (pink ignition wire)
Snip wire going to neutral light.
Relay 87a goes to the snipped (-) Neutral light wire which should be Light Green/Red and goes to bulb
Relay 30 connects to the snipped end of the Light Green/Red wire that goes to the solenoid (neutral light wire you snipped that goes back into the harness) AND you need to run a jumper to the green wire going to the CDI.
Been a few weeks since I did it, but I'm pretty sure that's it. @retro? That look right?
post #100 of 104 (permalink) Old 06-14-2019, 02:29 PM
Liked: 3154 times
Sounds right to me Jeep... do you need the jumper wire from relay #30 to the green CDI wire on 300s? I never did one of those 300s yet.
