2003 Honda 400ex Top End Rebuild - Honda ATV Forum
post #1 of 9 (permalink) Old 04-21-2019, 10:45 AM Thread Starter
Joe03400ex's Avatar
Hello all, My name is Joe i am From Central New Jersey.
I am currently Awaiting parts, but I am a little confused on what I should do with my upcoming project.
Currently the machine is bone stock with just a KN air filter with an outerwears sleeve over it... Quad started to burn some oil so here is my plan of action...
Wiseco top end rebuild kit .040 bore and 10:1 compression, all new gaskets and head studs, new cam gear and cam chain (keeping factory cam), rebuilding the head entirely hardware and seals. Kibble white stiffer valve springs, wiseco valves and all new hardware inside, going to add an ebc dirt racer clutch kit and completely rebuild the carb with factory jets.
The question I have is will I need to jet the carb and will I need to run a slip on exhaust? I like the stock sound on the bike it’s perfect for where we ride... I don’t want to change it if it is not necessary...
Any positive input would be greatly appreciated. Thanks in advance
Joe03400ex is offline
post #2 of 9 (permalink) Old 04-21-2019, 10:59 AM
Austin92's Avatar
Liked: 20 times
Building my own engine right now too. Hereís what Iíve learned since Iíve been on here that might help you. JE makes the lightest piston. The crf450r timing chain is an upgrade for our 400EX motors. Gt thunder head studs are the only ones that address them pulling the threads out of the jug.
I still havenít decided what I want to do with my valves and springs though.
Austin92 is offline
post #3 of 9 (permalink) Old 04-21-2019, 11:32 AM Thread Starter
Joe03400ex's Avatar
I had listed the parts I have already ordered. Will I have an issue with new oem head studs. I’m not trying to go with a complete performance build looking to keep reliability and make it just a tad better than stock.
post #4 of 9 (permalink) Old 04-21-2019, 12:49 PM
Austin92's Avatar
Liked: 20 times
I guess these 400ís are bad about blowing head gaskets and the gt thunder studs allow you to torque them a little tighter helping with the head gasket problem.
I would say you probably shouldíve jetted with just the air filter, a larger bore will definitely need more fuel. These come from the factory lean.
I donít think youíd NEED a slip on but it will make a difference in power. Dirt wheels magazine did an article on mufflers. Ct racing made the most power but you can change the disks out for different db levels. Stock is like 89db and the quietest the ct got was like 93db all the way up to like 101db. Louder settings made more power. Hmf has quiet core inserts for their mufflers too but wasnít reviewed in that article. Something to think about
Austin92 is offline
post #5 of 9 (permalink) Old 04-21-2019, 01:54 PM Thread Starter
Joe03400ex's Avatar
Originally Posted by Austin92 View Post
I guess these 400’s are bad about blowing head gaskets and the gt thunder studs allow you to torque them a little tighter helping with the head gasket problem.
I would say you probably should’ve jetted with just the air filter, a larger bore will definitely need more fuel. These come from the factory lean.
I don’t think you’d NEED a slip on but it will make a difference in power. Dirt wheels magazine did an article on mufflers. Ct racing made the most power but you can change the disks out for different db levels. Stock is like 89db and the quietest the ct got was like 93db all the way up to like 101db. Louder settings made more power. Hmf has quiet core inserts for their mufflers too but wasn’t reviewed in that article. Something to think about
What jet sizes would you recommend for the upcoming build? And when I drop everything off at the machine shop- should I just redo the head or should I have it ported and polished for the additional compression?
post #6 of 9 (permalink) Old 04-22-2019, 09:14 AM
XplicitRacing6's Avatar
Liked: 520 times
Everyone has there own opinions, hereís mine.
GT head studs are a waste of money. Buy ARP Studs
Second, itís hard too tell exactly what jetting you are going too need, it all depends on elevation, air temp, and all that good stuff
  • 2001 Honda TRX 416ex
  • 2003 Honda TRX 416ex
  • 1999 Honda 300ex
  • 2014 Polaris 1000 xp Turbo
  • 1998 Yamaha PW 80
XplicitRacing6 is offline
post #7 of 9 (permalink) Old 04-22-2019, 07:05 PM
Austin92's Avatar
Liked: 20 times
Depends on how you ride. Port and polish might kill your bottom end. Just a polish will help across the board though. When I was planning my build I was going to go with arp also but they use the same threads as stock. The gt thunders need drilled and retapped because theyíre bigger so theyíre less likely to pull out when you over torque them. More clamping force is less likely to blow the head gasket. But xplicit isnít wrong. Arp makes quality stuff too
Austin92 is offline
post #8 of 9 (permalink) Old 04-23-2019, 06:53 AM Thread Starter
Joe03400ex's Avatar
I’d use ARP over anything... that’s what holds down my turbo diesel....
post #9 of 9 (permalink) Old 04-23-2019, 06:54 AM Thread Starter
Joe03400ex's Avatar
I’m in nj there’s no real elevation here... riding in say 50 to 80į weather sometimes colder...
2000 TRX450FM Build/Mods fishfiles Builds, Projects & DIY 1044 05-18-2019 08:20 PM
Honda 400ex Rebuild XplicitRacing6 Builds, Projects & DIY 54 04-25-2018 06:41 PM
2003 Honda 400ex Front Right Tire copenhagenjonah Honda TRX 2 02-24-2016 04:29 PM
