2016 Honda 420 - Honda ATV Forum
 5Likes
post #1 of 15 (permalink) Old 07-10-2019, 11:45 PM Thread Starter
FraserS's Avatar
2016 Honda 420
Spark issues..... has really good spark when you first hit the start button and then there’s nothing for about 2-3 seconds what can it be
FraserS is offline
post #2 of 15 (permalink) Old 07-10-2019, 11:51 PM
GirlsRideToo's Avatar
Liked: 515 times
Is your batter fully charged?? That's the first thing to check.
Is battery new or older.
Has bike been sitting or used often?
GirlsRideToo is offline
post #3 of 15 (permalink) Old 07-10-2019, 11:54 PM Thread Starter
FraserS's Avatar
Brand new battery , spark plug and spark plug cap
FraserS is offline
post #4 of 15 (permalink) Old 07-10-2019, 11:56 PM Thread Starter
FraserS's Avatar
It was running this winter and when I tired starting it this spring it won’t start
FraserS is offline
post #5 of 15 (permalink) Old 07-11-2019, 12:38 AM
Liked: 515 times
It was running this winter and when I tired starting it this spring it wonít start
The problem is that there could be several issues. It's always smart to start with the most simple causes of the problem and go from there or you could end up spending a bunch of money needlessly.
Okay, you said the battery is new. Are you positive it is fully charged?? Put in on a trickle charger to be sure. New batteries are not always fully charged.
Recheck your battery connections. Use a wire brush to clean the connectors if needed.
Did you install a NGK spark plug? If not, you need to.
Check for a loose connection at the PCM/ECM. I think it's gray in color and is located forward of the seat.
Check the starter motor cable connection. Disconnect it, clean and reconnect.
Since it seems to be dropping voltage it's not likely, but be sure your kill switch if OFF. LOL
retro likes this.
post #6 of 15 (permalink) Old 07-11-2019, 11:42 AM Thread Starter
FraserS's Avatar
Cleaned all the posts off unplugged the ECM plugged it all back in and still nothing ... I tried the ecm from the broke down quad on a different quad it runs with it I tired the coil and cap as well they all work on a different quad ....can it be a stator issue ???
FraserS is offline
post #7 of 15 (permalink) Old 07-11-2019, 12:44 PM
rustynut2's Avatar
Liked: 62 times
Does it have a hand start on it.. Wondering if the flywheel bolt wasn't torqued and it has sheered the key.
I have way to much experience on that pull starter assembly and rear crank bearing, don't ask.
retro likes this.
Work harder, millions on welfare depend on you.
16 Rancher 4x4, 12 T800XC, 14 DRZ 400s
rustynut2 is offline
post #8 of 15 (permalink) Old 07-11-2019, 01:24 PM Thread Starter
FraserS's Avatar
It does have a pull cord on this unit ....
FraserS is offline
post #9 of 15 (permalink) Old 07-11-2019, 01:26 PM Thread Starter
FraserS's Avatar
Wouldn’t you think It would have sheared off awhile ago .. it has 9500km on it
FraserS is offline
post #10 of 15 (permalink) Old 07-11-2019, 02:24 PM
rustynut2's Avatar
Liked: 62 times
Remove the hand crank and see if the adapter assembly is loose on the back of the flywheel. You might need to remove the air box.
This is just my guess
I will tell you my story if you find this to be the problem, its embarrassing.....
