2007 Honda Rancher Won't Start - Honda ATV Forum
 4Likes
post #1 of 11 (permalink) Unread 06-25-2019, 07:00 PM Thread Starter
ameads95's Avatar
Question 2007 Honda Rancher Won't Start
Good evening, I have a 2007 Honda Rancher 420 2wd Manual Shift. To start from the beginning, battery died, tried to charge it, it started, shut off now will not do any thing. It keeps blowing the 10A IGN Fuse and Fuel Pump will not run like normal when the key is turned to the on position. I have pulled all of the electrical connections in the back of the bike and plugged in until the fuse blows. Originally, i found that when i plug the relay that is in the back into its connection, it immediately blows the fuse. I thought it was the relay, ordered another, and same issue continues. When the relay is not plugged in, the bike will turn over all day long, (Still nothing from the fuel pump and will not start, just turns over) with all of the connections connected or disconnected, except for the starter solenoid of course. When i plug that relay in, if all connections are connected it will blow the fuse. If the right one is plugged in (grey) and the left one unplugged (Black Square) (At the back of the bike facing forwards) the relay makes a buzzing noise. Also noticed today, with all of the electrical connections together, the right plug (grey) (at the back of the bike facing forward) the wires going get hot to the touch. Any help would be much appreciated.
ameads95 is offline
post #2 of 11 (permalink) Unread 06-25-2019, 09:22 PM
Liked: 3149 times
It sounds like the fuel pump is seized up. Or there is an issue with one of the relays. Try unplugging the pump and see if it quits blowing that IGN fuse.
EDIT: You can find a free copy of the service manual here:
https://www.hondaatvforums.net/forum...downloads.html
ID:	137518   Click image for larger version
Jeepwm69 and _Wilson_ like this.
post #3 of 11 (permalink) Unread 06-26-2019, 07:55 AM
Liked: 3238 times
Welcome to the forum
post #4 of 11 (permalink) Unread 06-27-2019, 06:54 PM Thread Starter
ameads95's Avatar
@ Retro that was the very first thing i tried. I forgot to mention that. i unplugged the fuel pump and it still blows the fuse. the relay is new, just got it in tuesday.
ameads95 is offline
post #5 of 11 (permalink) Unread 06-27-2019, 08:00 PM
Liked: 3149 times
Is it the fuel pump relay that blows the fuse? Or is it the relay next to that one? Do you have a copy of the service manual?
post #6 of 11 (permalink) Unread 07-03-2019, 05:58 AM Thread Starter
ameads95's Avatar
It is the "Fuel Pump Waterproof Relay".
retro likes this.
ameads95 is offline
post #7 of 11 (permalink) Unread 07-03-2019, 06:30 AM
_Wilson_'s Avatar
Liked: 1803 times
Welcome aboard!
_Wilson_ is online now
post #8 of 11 (permalink) Unread 07-03-2019, 11:33 AM
Liked: 3149 times
You replaced that "Fuel Pump Waterproof Relay" already, correct? Is that a genuine Honda part number or a china knockoff you found on the 'net cheaper?
That leaves either a bad/incorrect/china relay, or shorted wiring to ground in the harness as likely possibles.
You can trace possible shorts using a multimeter. If the relay is not an OEM Honda part then its gotta be replaced with one.
post #9 of 11 (permalink) Unread 07-04-2019, 07:53 PM Thread Starter
ameads95's Avatar
Yes already replaced the "Fuel Pump Waterproof Relay". I bought it from my local Honda Dealer so it should be a good part. That is my next step, to start with the volt meter. Electrical issues are nightmares...
retro likes this.
ameads95 is offline
post #10 of 11 (permalink) Unread 07-04-2019, 10:11 PM
Liked: 3149 times
Try unplugging the ignition coil, the bank angle sensor and the fuel injector one at a time.
EDIT: Forgot to mention the engine stop relay... check that too.
ID:	137806   Click image for larger version
ID:	137808   Click image for larger version
ID:	137810   Click image for larger version
