97 300 EX no start via push button. - Page 4 - Honda ATV Forum
 10Likes
post #31 of 69 (permalink) Old 05-17-2019, 06:33 AM
Melatv's Avatar
Liked: 305 times
When you tried powering the solenoid -- what is the battery voltage reading when testing the solenoid?
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is offline
post #32 of 69 (permalink) Old 05-17-2019, 07:03 AM Thread Starter
Sarahleeomg's Avatar
Liked: 5 times
The battery was at 12.84
Sarahleeomg is offline
post #33 of 69 (permalink) Old 05-17-2019, 08:44 AM
misterclean59's Avatar
Liked: 551 times
If the terminals are corroded at any of the four ends you can have good voltage but low amps. Make sure the ends of the large cables are making good contact.
misterclean59 is online now
post #34 of 69 (permalink) Old 05-17-2019, 12:51 PM Thread Starter
Liked: 5 times
Okay -- do this remove the Y/G wire off the solenoid and ground the Y/G wire on the solenoid side to frame or battery neg. see if it will start.
Ok. I got ANOTHER brand new solenoid. Still nothing. All wires are tight no corrosion. I did notice however that the wire to started is actually welded on 🙄. Not sure if this would make a difference as the starter still engages as I jump the solenoid. I seems as if the solenoid isn’t getting a ground.
Is there a list of grounds for this bike or can anyone point me in the right direction ?
Thanks.
misterclean59 likes this.
post #35 of 69 (permalink) Old 05-17-2019, 01:02 PM
Liked: 551 times
I"m not sure if the solenoid needs to be grounded. If it does this should be easy. Just sand a clean spot where it mounts to the frame or chase it's ground wire to the frame. You could rig one for testing purposes by clamping a wire to the frame of the solenoid with small vices grips and do the same at the battery ground terminal.
post #36 of 69 (permalink) Old 05-17-2019, 01:04 PM
Liked: 551 times
It really think that there is not enough voltage or amps going to the small wire at the solenoid. Jump a wire from the positive battery post straight to the small wire at the solenoid. This will by pass all the switches etc.
post #37 of 69 (permalink) Old 05-17-2019, 01:35 PM Thread Starter
Liked: 5 times
Which small wire? Y/r or y/g? Thanks
post #38 of 69 (permalink) Old 05-17-2019, 03:46 PM Thread Starter
Liked: 5 times
Yellow red or yellow green?
post #39 of 69 (permalink) Old 05-17-2019, 05:24 PM
Melatv's Avatar
Liked: 305 times
You said you did that with old solenoid. ---- Y/G wire on solenoid jumper it to the battery neg. --- Y/R wire on solenoid just touch it on the battery pos. --- make sure the bike is in neutral
2500 Runva Winch
Melatv is offline
post #40 of 69 (permalink) Old 05-17-2019, 06:25 PM Thread Starter
Liked: 5 times
Yeah just did again. Nothing happens
400ex Start button failure Robdebone Repair & Maintenance 0 09-23-2017 01:10 PM
push button start christyh New Member Introductions 5 04-03-2017 05:40 PM
Trx 400 start button not working BEARDEDJEEPER2 Repair & Maintenance 2 04-01-2017 01:23 PM
Push button start doesn't work Jcole Repair & Maintenance 4 08-09-2016 05:01 AM
Help! 02 300ex won't start off button Jim.sharp99x ATV General Discussion 9 03-20-2016 12:14 PM
