2005 Honda rancher 350 4x4 front drive shaft help - Page 2 - Honda ATV Forum
 7Likes
post #11 of 16 (permalink) Old 05-03-2019, 04:52 AM
Liked: 6298 times
I would wonder why the previous owner would have gone thru all the trouble to remove the shaft , only thing I could think of that would warrant that is a blown front diff and he was trying to figure out how to ride it in two wheel drive
misterclean59 and _Wilson_ like this.
fishfiles is offline
post #12 of 16 (permalink) Old 05-03-2019, 08:24 AM
Liked: 2768 times
Someone put hi-temp RTV gasket maker on those cases when they put it together and he/she did a sloppy backyard slam job on it. Scrape and remove all of those orange RTV pieces from the case and cover. Clean it up real good and hope that the oil pickup screen is not completely clogged up already.
misterclean59 likes this.
post #13 of 16 (permalink) Old 05-10-2019, 10:17 AM Thread Starter
whitcraft.william's Avatar
I did that as well used a plastic razor blade to clean it off of both the cover and the crankcase. The oil seal has still not been delivered. Honda powersports said that for some reason it was held up in Georgea and should be delivered today. In the mean time I stripped off the plastics, cleaned and painted everything. Here are some before and after pictures. 2005 Honda rancher 350 4x4 front drive shaft help-20190430_022928_1557504914631.jpg2005 Honda rancher 350 4x4 front drive shaft help-20190430_120541_1557504940595.jpg2005 Honda rancher 350 4x4 front drive shaft help-20190506_141157_1557504963331.jpg2005 Honda rancher 350 4x4 front drive shaft help-20190508_141604_1557504985622.jpg2005 Honda rancher 350 4x4 front drive shaft help-20190509_121930_1557505012849.jpg
whitcraft.william is offline
post #14 of 16 (permalink) Old 05-11-2019, 09:51 PM Thread Starter
So I put the final drive in and installed the oil seal. Put the cover on and now it seems like the clutch is slipping. It shifts into gear, but only moves slightly in 1st and second the other gears seem to slip. It rode fine a week ago, so I'm pretty sure it's just some kind of adjustment I made. The tension screw on the front helped a little, but I'm wondering what else could be off.
post #15 of 16 (permalink) Old 05-12-2019, 10:43 AM
Liked: 4210 times
its posb you did not put it back together right ?. but before you go removing the front cover, try adjusting the clutch first.
post #16 of 16 (permalink) Old 05-12-2019, 03:37 PM Thread Starter
its posb you did not put it back together right ?. but before you go removing the front cover, try adjusting the clutch first.[/QUOTE]
I fixed it. I had to remove the front cover and clean up the clutch adjuster it came undone trying to loosen the nut on the outside. It was so corroded I couldn't adjust it correctly. It's working great now. Thank you.
Jeepwm69 likes this.
2014 Honda Rancher drive shaft problem Veno429 Repair & Maintenance 3 04-01-2019 07:41 AM
2017 rancher rear drive shaft Mrgoodwrench35 Honda Rancher 11 08-02-2018 06:58 PM
2005 Honda Rancher; oil dripping out of air filter. 70monte Repair & Maintenance 5 07-05-2016 03:51 PM
Front differential test on my new '16 Honda Rancher 420 4x4 creed82 Honda Rancher 12 05-03-2016 05:51 PM
