1987 250x - Honda ATV Forum
post #1 of 16 (permalink) Unread 07-04-2019, 06:40 AM Thread Starter
tylerjones's Avatar
1987 250x
I bought my first semi-vintage bike, when I went to test ride the bike he had the idle turnt up pretty high. I test drove it bought it went home, opened my new toy before I got home (as every kid does lol) parked it. Last night I cleaned the carb and diaphragm out. I put the setting ton the carb back to where they was before I tore it does except for the throttle speed. I turnt it down so ots not high revving. I cranked her up, she would idle but not move, so I removed the side cover on the right side of the bike covering the throttle cable and pumped on the diaphragm because when I hit the gas it did not move well. So I got the bike to drive after that, she hesitates when I give it gas but it will slowly get up to speed if I dont hit the gas hard. After the test ride she cut off and wouldnt crank. She was really hot as well, hotter than normal. I pulled the spark plug and it was black. Cleaned it, installed it back and she cranked up. But yet she is running hot still. I know cleaning the plug wont cool it down. So I ordered a carb rebuild kit, that will be here sunday. Is there anything else that I should do to help cool this thing down or maybe is it my fault for inproper carb adjustment? I'm going to adjust the valves today as well and tinker with the carb until the new parts get here
tylerjones is offline
post #2 of 16 (permalink) Unread 07-04-2019, 07:25 AM
Liked: 1382 times
I think you’re doing all the right things there sofar except maybe the getting hot bit.
Check the service manual to see how the cooling system sposda work—it doesn’t have a cooling fan and likely not an overheat protection system but should have a hot light.
Test the oil temp sensor to see if it works
What carb number is it? QB01A? Does the choke work on the carb? If it sputters when warm then maybe not or pilot screw too far out.
Did you assemble the pilot screw in the right order? Tiny oring on top, tiny washer, tiny spring
Goober is offline
post #3 of 16 (permalink) Unread 07-04-2019, 09:27 AM
SlammedRanger's Avatar
Liked: 1251 times
The 250x dosnt have any sort of cooling help. It is an air cooled only. Dosnt even have an oil cooler. Just fins on the side of the motor. That being said at idle it will get very very hot. Not so hot it seizes but way hotter than most other engines. Black plug means your running rich. Which is what you want. Could also be a very very old worn out spark plug tho aswell. I would start by getting it to ride fast enough to get the air cooling fins working to your advantage before getting to worried about the hot motor. Unless its glowing red or seizing that is lol.
07 416ex
To many mods to list in signature(ran out of space lol)
Check out garage for full list
SlammedRanger is online now
post #4 of 16 (permalink) Unread 07-04-2019, 11:43 AM Thread Starter
tylerjones's Avatar
So I tore down the carburetor again to tinker around before the new parts came in, everything's there like it should be from reading the manual. I lowered the clip on notch on the throttle needle I noticed that the guide on the other side of the carburetor has threads and an adjustable nut on it. How do I go about knowing if that is at the proper height?
I rebuilt the carb slaped it on and it fired up first kick, it runs smooth until you get on it. It acts like the reve limiter is engaging! Is that to much fuel being dumped at once? Can I fix that problem? Or does that mean theres not enough fuel to catch up with the acceleration?
post #5 of 16 (permalink) Unread 07-04-2019, 12:07 PM Thread Starter
tylerjones's Avatar
It sounds like the choke is engaged until it clears up
post #6 of 16 (permalink) Unread 07-04-2019, 12:39 PM Thread Starter
tylerjones's Avatar
This is the piece I mentioned I'm not sure how this needs to be adjusted
post #7 of 16 (permalink) Unread 07-04-2019, 12:55 PM
Liked: 1251 times
The reason that is like that is so the fuel pulls from the bottom of the bowl. The reason they do that is for going up or down hills so it wont starve the main jet for fuel unless its completely upside down. Now that being said if that was adjusted down so far its touching the bottom it wouldnt get any fuel from the main jet. Which could be your problem. The best thing to do to set it right is to put the bowl back on and remove the bottom 17mm round cover. You will be able to see where the tip of the main jet sits and it should be about 1/4 inch down in. Not flush or sticking out at all. If its either of those its adjusted wrong.
07 416ex
post #8 of 16 (permalink) Unread 07-04-2019, 01:21 PM Thread Starter
tylerjones's Avatar
That's how far it is I assume it needs to scoot down some?
post #9 of 16 (permalink) Unread 07-04-2019, 01:28 PM
Liked: 1251 times
Yeah i would adjust it down alittle more.
07 416ex
post #10 of 16 (permalink) Unread 07-04-2019, 02:05 PM Thread Starter
tylerjones's Avatar
Well I adjusted it as far as it would go which was not further than where it was at in the picture. It drives better, when I hit the gas it still has a delay but it pheesable until the rebuild kit comes in.
