1986 Honda trx350 running rich - Honda ATV Forum
 4Likes
post #1 of 20 (permalink) Old 05-16-2019, 10:40 AM Thread Starter
86Hondatrx350's Avatar
Liked: 9 times
Hello,
I have a 1986 Honda trx350 that is running rich (oem carb). It pumps out black smoke till warmed up then if reved when warmed up it pumps black smoke out. It idles normally for a bit then shuts off after a bit and noticed that it pops when reving down. I’ve messed with the screw hanging below the carb but it hasn’t made a bit difference.
I have no experience rebuilding or tuning carbs only cleaning them. The previous owner told me that he had drilled out the carb at one time and I think put a bigger jet in but not really sure.
Is there are any good aftermarket carbs that I could buy? Or should I find a way to fix it?
Thanks!
86Hondatrx350 is offline
post #2 of 20 (permalink) Old 05-16-2019, 01:10 PM
Liked: 4259 times
do not use or even think about after market carbs for that atv !. if your old oem carb has been drilled out ?, your best bet is look for a oem used carb, and rebuild it with a shindy carb kit. AGAIN...DO NOT USE ANY AFTER MARKET CARBS ON THAT ATV !!!.
post #3 of 20 (permalink) Old 05-16-2019, 01:24 PM
Liked: 1341 times
Maybe he didn’t do anything to it but drill the replaceable jet.
You definitely want a Keihin QA03A that’s the oem for it. They are available on fleabay just not cheap–i bought one for $80 and after putting a $40 starter valve, $25 baffle and $25 rebuild kit in it i installed on my project 86.
The main jet is a 142, but i put 138.5 in mine and the high altitude jet is a 132? I run borderline high altitude so i think it helps.
so you should take your carb apart and see whazzup. Get a rebuild kit and a starter valve we’ll help you thru it—the Shindy kit comes with all new jets.
If the PO drilled anything on the carb itself , you can still keep it for parts.
misterclean59 likes this.
Goober is offline
post #4 of 20 (permalink) Old 05-16-2019, 07:22 PM Thread Starter
Liked: 9 times
Thanks for the quick responses,
I looked back in my messages and I still have the PO added, asked him what he drilled out and he said it was the choke slide, said it seized and he had to free it up. So does that mean I’m good then?
post #5 of 20 (permalink) Old 05-16-2019, 08:14 PM
Liked: 1341 times
You will have to pull the starter jet to see if itís too loose in the bore.
In a warm engine When you flip the choke ON what happens? Nothing? It dies?
Goober is offline
post #6 of 20 (permalink) Old 05-16-2019, 11:21 PM
Liked: 4259 times
I think he was talking about just drilling the choke enrichment valve, not the bore ?.
post #7 of 20 (permalink) Old 05-16-2019, 11:23 PM
Liked: 4259 times
Maybe he didnít do anything to it but drill the replaceable jet.
You definitely want a Keihin QA03A thatís the oem for it. They are available on fleabay just not cheapĖi bought one for $80 and after putting a $40 starter valve, $25 baffle and $25 rebuild kit in it i installed on my project 86.
so you should take your carb apart and see whazzup. Get a rebuild kit and a starter valve weíll help you thru itóthe Shindy kit comes with all new jets.
I looked back in my messages and I still have the PO added, asked him what he drilled out and he said it was the choke slide, said it seized and he had to free it up. So does that mean Iím good then?
if it was just the enrichment valve, and not the bore itself ?, then yes, you are good to use that carb with a rebuild kit, you will how ever need to purchase a new choke enrichment valve if you do not have a good valve ?.
post #8 of 20 (permalink) Old 05-17-2019, 05:58 AM Thread Starter
Liked: 9 times
You will have to pull the starter jet to see if it’s too loose in the bore.
How could I check if I need a new enrichment valve, I know the choke works fine but the PO said it was hard to get the carb set right after he drilled the choke to free it up. He also said something about somebody at his work removing the jets but said nothing about drilling them.
I can’t find a shindy rebuild kit, if I can find one I’ll buy it then start screwing with the carb once I get the kit.
post #9 of 20 (permalink) Old 05-17-2019, 06:35 AM
Liked: 1341 times
Here are some ideas, but yes you will have to disassemble the carb to ensure it is clean and see if it’s been molested.
It would be best if you had the Shindy rebuild kit because it contains new jets. the gasket kit shown contains the passage plug. You may need a new starter valve.
Last pic is of two junked carbs I bought and rebuilt for the practice. You should try it. I think I bought one for $25.
Before you start. Do you have the service manual? You have to set up the carb with the pilot screw like 1.75 turns from seated. Ensure you initially take all the slack out of the throttle cable. Reply back when you have read the service manual on this task.
ID:	136556   Click image for larger version
ID:	136558   Click image for larger version
ID:	136560   Click image for larger version
ID:	136562   Click image for larger version
Goober is offline
post #10 of 20 (permalink) Old 05-17-2019, 06:43 AM
Liked: 1341 times
Buy this book!
Best seller; classic read lol
Goober is offline
1988 Honda fourtrax same size frame at Honda 1986 trx 250 se1ch3r ATV General Discussion 1 08-15-2017 07:32 PM
1986 Honda TRX 125 gas tank Haybale Honda TRX 5 07-31-2017 06:38 AM
1986 Honda 350 fourtrax upper steering sloppy Okie Honda TRX 21 12-03-2016 04:45 AM
1986 Honda 350 4x4 no power wehekman3 Repair & Maintenance 3 01-13-2016 12:12 AM
Trying to get 1986 Honda 250 TRX running tweb74 Repair & Maintenance 3 11-30-2015 03:52 AM
