2002 Honda recon metal in oil - Honda ATV Forum
 3Likes
post #1 of 13 (permalink) Old 03-23-2019, 04:30 PM Thread Starter
Thundermonkey's Avatar
Hey guys I want to know if glitter/metal is normal in oil after somewhat hard running conditions but under a very short drain interval?! Oil used was supertech 10w40 conventional and oci was about 2 hours of run time. The recon has many hours of run time around 10,000 hours last time I checked compression it was 200psi but I’m worried I may have hurt the engine.
ID:	134950   Click image for larger version
ID:	134952   Click image for larger version
Thundermonkey is offline
post #2 of 13 (permalink) Old 03-23-2019, 04:59 PM
Liked: 4215 times
was this oil made for wet clutches ?. from looking at your pics ^^^, seems to me you have something wearing causing all that metal in the oil.
post #3 of 13 (permalink) Old 03-23-2019, 05:05 PM Thread Starter
No this oil is not certified for wet clutches I thought I’d try it out because other people have had decent results out of it. I had noticed the clutch wasn’t grabbing as well I wasn’t able to spin the tires well at all in wet soil and gravel I have changed the oil and put in amsoil 0w40 and a little mix of delo 400sde.
post #4 of 13 (permalink) Old 03-23-2019, 05:08 PM Thread Starter
The clutch is grabbing like it did before the supertech when I put the jaso ma rated amsoil in it. The valves have never been adjusted either could this be a factor in all the metal in the oil? It does have a notable tick while running.
post #5 of 13 (permalink) Old 03-23-2019, 05:49 PM
Liked: 4215 times
ticking could be from just about anything ?, valves ?, cam chain ?, who knows ?. what I do know is, NEVER RUN ANY OIL IN AN ATV THAT IS NOT MADE FOR WET CLUTCHES !. as to why you have metal in your oil ?, hard to say ?, I doubt its from your clutches though ?, I just don't know ?. when I see metal like that in the oil ?, this tells me something is wrong somewhere ?!. could be rings ?, piston skirt ?, bearing shavings ?, some where its making contact inside the engine where its not suppose to be ?. hard to say at this point :-).
Goober likes this.
post #6 of 13 (permalink) Old 03-23-2019, 06:16 PM Thread Starter
I agree that something is making contact where it shouldn’t be I wonder if using high end oils was masking this issue all along thanks for the tip to never use anything not rated for wet clutches.
post #7 of 13 (permalink) Old 03-23-2019, 06:22 PM
Liked: 4215 times
yw. using any oil other than oil made for wet clutches just causes problems. reason: reg auto oil has friction modifiers in it, so this makes it very slippery !. were is oil made for wet clutches does not. in other words, auto oil will make your clutches ( friction disk ), and centrifugal clutch if it has it ? ( the arm weights ) slip big time !, which will burn them up over a short time :-).
Goober likes this.
post #8 of 13 (permalink) Old 03-23-2019, 06:24 PM Thread Starter
One thing I should note is the engines tick is a lot louder intill the engine runs for a few seconds after startup then it quiets down to a softer tick.
post #9 of 13 (permalink) Old 03-24-2019, 07:41 AM
Liked: 1309 times
I would check cam chain slack to be sure but could use a replacement. Compression might be good but sounds like you have a ton of hours on it.
Goober is online now
post #10 of 13 (permalink) Old 03-24-2019, 11:15 AM
Liked: 4215 times
17 yrs old, I would bet the cam chain needs replacing, and valves checked/adjusted !.
2002 Honda recon Es. Smoking bad! LotusCampbell Repair & Maintenance 9 03-05-2019 09:38 AM
2002 honda recon 250 died out and won't fire back up. cliffcollins72 Around The Garage 4 04-03-2018 07:28 PM
2002 honda recon wont idle....help please sharnold ATV General Discussion 7 05-08-2016 02:31 PM
