2007 420FM electric shift- no gear display - Honda ATV Forum
post #1 of 9 (permalink) Old 05-27-2019, 02:57 PM Thread Starter
2007honda420's Avatar
Hello, I have changed shift angle sensor, tested gear switch, tested continuity on wiring from gear switch to ecm, to display, all ok...still no gear display. What am I missing, please help.
2007honda420 is offline
post #2 of 9 (permalink) Old 05-27-2019, 06:48 PM
Hawire's Avatar
Liked: 9 times
Have you checked your fuse? I’ve got one I’m fighting now. Sometimes it is just the fuse. Of course I find that out after I check everything else
Hawire is offline
post #3 of 9 (permalink) Old 05-30-2019, 11:12 AM Thread Starter
All fuses are good
post #4 of 9 (permalink) Old 05-30-2019, 11:14 AM Thread Starter
Is there more fuses elsewhere then under seat? Main, ign, fan, acc?
post #5 of 9 (permalink) Old 05-30-2019, 01:43 PM
Hawire's Avatar
Liked: 9 times
Not that I know of
Hawire is offline
post #6 of 9 (permalink) Old 05-30-2019, 01:45 PM
Hawire's Avatar
Liked: 9 times
Have you tested the throttle position sensor? Maybe a long shot, but I can cause the dreaded “- -“ to pop up.
Hawire is offline
post #7 of 9 (permalink) Old 05-30-2019, 02:23 PM
Liked: 3087 times
Gear switch could be bad. Display could be bad.
post #8 of 9 (permalink) Old 05-30-2019, 04:00 PM
Hawire's Avatar
Liked: 9 times
Do you have the service manual for this atv? There is a download on here, somewhere. You’re absolute best bet is to get that. Go through how to get the trouble code section and see what it says about how many flashes you get. That’s the very best way to start. If not, you’re throwing darts blindfolded.
Hawire is offline
post #9 of 9 (permalink) Old Today, 07:17 AM
ClutchTFS's Avatar
Liked: 6 times
I know Im a little late to reply but, if nothing else its the ECM... thats what it turned out to be on mine... the shift motor circuit (which is INSIDE of the ECM) somehow got water in it and shorted out, which prevents the hondamatic system from sending a signal to the shift motor (so the signal will make it from the shift sensor or shift button (depending on if your in auto or esp) to the ECM but will not make it past there because the physical connection inside the ecm is damaged). Luckily I was able to bypass this and save myself from spending 300$ on an ECM by wiring up relays between the shift buttons and the shift motor directly without the use of the ECM. I've attached a diagram of how mine is setup (diagram varies slightly as there is only one + line going to the shift buttons and 2 + outputs (one from up shift and one from down shift)). Feel free to message me if you have any questions. Best of luck
Name:	Honda Updated Custom Shift System.png
06 Rancher TRX400FGA - Keeper 2500lb winch, 1.5" snorkel kit, 25" Dirthooks, 30W 7" LED Lightbar, 2x30W 2x2" Cube LEDS, Reverse Lights, Running Taillights, Pyle 8" Soundtube, 50" Kimpex Straight Blade Plow w/Custom 2500lb Winch Angling System
19 Rancher TRX420FM1 - Bone Stock
ClutchTFS is online now
